Will 16x8 4.5" BS fit with spacers
Discussion in 'Wheels & Tires' started by Darrylb, Dec 16, 2010.
  1. Dec 16, 2010 at 4:37 PM
    Darrylb
    Darrylb [OP] Well-Known Member
    Looking at getting some black wheels for my 08 DC.
    I like the wheelers steelies because I know they will fit, but the extra 20 lbs per wheel over an alloy wheel is alot.
    The wheelers alloy (procomp 8069) are good looking wheels, and not too pricey. I don't want to grind calipers. If I get the type A with 4.5" BS and I put a 1/4" spacer in, will that clear the caliper? I'm trying to stay away from a 4" BS and a spacer. (don't want to stick out too much).
    BTW I searched for a while and couldn't find anything.
  2. Jan 24, 2011 at 8:25 PM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Chicago
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    Im looking at the same wheels. I heard that you might have to do a lil bit of grinding. Id also like to know how much if any is needed??
