Will 16x8 Mickey Thompson Sidebiter II wheels fit my 04 Double cab tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by aestheticbrah, Nov 18, 2015.
  1. Nov 18, 2015 at 2:28 AM
    aestheticbrah
    aestheticbrah [OP] Well-Known Member
  2. Nov 18, 2015 at 12:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It may be that clearing your brake calipers might be an issue.
    I would think those wheels in the 16x8 size with the proper bolt pattern would fit most 1st gens. However, some '04 models had special front brakes, referred to as VSH or something like that. Those larger brakes created clearance issues on some aftermarket wheels.
  3. Nov 18, 2015 at 12:16 PM
    aestheticbrah
    Ah. Ok. I just called Mickey Thompson and the guy told me that I would have to go to a retailer and have them fit checked because "Toyota brake calipers are inconsistent." Damn I really like these wheels.
  4. Nov 19, 2015 at 10:19 AM
    aestheticbrah
    Anybody else?
  5. Nov 21, 2015 at 2:35 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    I have them in 15x8 on my 01
  6. Nov 26, 2015 at 12:53 PM
    T@codawg
    T@codawg Well-Known Member
    Mark
    Nashville
    99 TRD PreRunner Xtra Cab
    Full OME 881's w/nitros & Dakar leafs in rear
    That's what I want to put on my 99. Will they fit your 04? What have you found out? Thanks
