will 17" rims fit on stock tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TACO3, Aug 24, 2010.
  1. Aug 24, 2010 at 7:47 PM
    TACO3
    TACO3 [OP] Deer Dropper
    Aaron
    VA
    03 tacoma 4wd 4 banger
    I gotta buddy who has a set of 17" wheels off a newer tacoma. if i put these on my stock 00 tacoma whats the biggest size tire i can run with no lift?
  2. Aug 24, 2010 at 7:50 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    hubcentric vs lugcentric
  3. Aug 24, 2010 at 10:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Those +05 Tacoma sport rims tuck in further that the stock rims on a 1st gen. This may cause a rubbing issue on the UCAs if wide tires are mounted.
    Without knowing a lot more about your truck it is very difficult to say what is the biggest tire you can mount without problems.
  4. Aug 25, 2010 at 11:38 AM
    kyle39
    kyle39 Reppin' BC
    Kyle
    Vancouver BC
    04 Tacoma Trd
    Deck plate mod, rhino lined, A.r.e. flush glass shell, 265/75/16 Duratrac's, MB72 rims, Full OME lift, Dakars in the rear, Tint allround
    can anyone confirm they rub on 265/70/17??
  5. Aug 25, 2010 at 3:27 PM
    HUNT
    HUNT Well-Known Member
    Tommy
    Wildwood Ga
    2003 Double cab 4x4
    Bilstein 5100 set @ 0, OME 881,Wheelers 5-leaf, OME NitroCharger Sport shocks, 4-RUNNER LIMITED WHEELS, Duratracs, 265/75/16
    THEY DID RUB ON MY 1999 4RUNNER.HAD TO RUN A 1' WHEEL SPACER TO CLEAR THE UCA.....
  6. Aug 26, 2010 at 2:17 PM
    scriber007
    scriber007 Well-Known Member
    Here are some info about this type this in
    Pro & Cons of installing 2nd Generation TRD Wheel/Tires on 1st Generation TRD Taco
