Will 17in. wheel and tires fit on a stock 08 Prerunner?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ERdept, Feb 23, 2008.
  1. Feb 23, 2008 at 8:16 PM
    ERdept
    ERdept [OP] Well-Known Member
    I posted this on TN but no one could answer.
    Can 17inch wheels and the tires that go with them fit on the Toy, Tacoma, TRD Prerunner, w/o any rubbing issues?
    And, will it raise the truck any if they do fit?
  2. Feb 23, 2008 at 8:29 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the sport comes w/ 17" rims....so it depends on the backspacing and the tire size
  3. Feb 23, 2008 at 8:46 PM
    rick
    rick `
  4. Feb 23, 2008 at 9:42 PM
    ERdept
    I don't know what that means to me. This is just info at this point, but how do I know if 17 inch tires and wheels fit?
    I appreciate the info so far.
    I just don't know how to apply this to my truck. What do I do?
  5. Feb 23, 2008 at 10:24 PM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
    You mean, can 17" TRD wheels replace your 16" wheels?
    Yes they can. All Toyota 6 lug wheels can be swapped.
    What size are your current tires? What size tires are on the 17" wheels you're looking at?
    16" wheels is the smallest you can fit on a 6 lug truck.
    I think 15" wheels will fit on 5 lug Tacomas, because they have slightly smaller brake calipers.
  6. Feb 23, 2008 at 11:01 PM
    ERdept
    I have the 266/70/16 tires currently on the truck. So, I assume it's a 16 in wheel.
    So a 17 inch wheel will fit on it, but with a larger tire, will it rub on the fender?
    Also, I don't really know what tires fit on the 17 inch wheel. Will a larger tire lift the truck about 1 inch?
    Can you suggest a tire that will fit on the 17 inch wheel and take a larger tire?
    AND
    Will this larger tire and wheel combo work on the truck W/O any problems?
  7. Feb 24, 2008 at 3:39 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Let me see if I've got all this....
    You have a set of 265/70 r16's now. and want to go to 17" wheels and get an inch of overall lift on the truck without touching the suspension or trimming the fenders.
    Atleast I think that is what you are asking.
    The short answer is no. The general consensus is you can go up one tire size without a lift and without any rubbing issues. So if you just changed tires on your current 16" wheels you could go to 265/75 r16.
    Or you could use TRD sport 17" wheels with 265/70 r17 tires.
    In either case you have gone from roughly a 30.5 inch tall tire to a 31.5 inch tall tire, or a roughly 1 inch difference in tire size, but that is one inch diameter, and you're only getting the "lift" of the radius of the tire so by changing your tires and or tires and wheels the best you can do is a half inch change in the ride height before lifting the suspension or trimming the fenders.
    As for what 17" rims you can choose from, I'll leave that question more for the wheel and tire guys as I really don't know what aftermarket wheels will maintain the correct backspacing.
  8. Feb 24, 2008 at 7:27 AM
    pb2themax
    TRD Sport 4x4
    ^Yup.
    The stock wheels have 5.5" backspace. With aftermarket wheels and bigger tires you usually want the wheels to stick out about inch more than the stock wheels for a sportier look, which would be 4.5" of backspace, which is what I have on my truck. I have 17" wheels too.
  9. Feb 24, 2008 at 8:44 AM
    CNW
    CNW Well-Known Member
    Colorado Rockies
    4x4, Radiant Red, Chrome Wheels, Tonneau
    My DC TRD 4x4 came with 17 inch wheels OEM. Lots of room. No rubbing. I put chrome wheels, but stayed the same size.
    Craig
  10. Feb 24, 2008 at 8:45 AM
    CNW
    Colorado Rockies
    BTW you can check out my photos.
    Craig
  11. Feb 24, 2008 at 1:07 PM
    ERdept
    OK, this pretty much answers my question perfectly.
    Let me reiterate. I know is sounds childish, but I just want to be sure I understand.
    I can do one of two things that won't interfere with rubbing:
    1. I can put on a 17 inch wheel and the larger tire that goes with it, such as a 265/70/17.
    2. Or, I can stay same size wheel I have currently and put on a taller tire such as the 265/75/16.
    Is this correct?
    Also the increase in the height of the vehicle will be 1/2 inch, if that?
  12. Feb 24, 2008 at 1:43 PM
    maverick491
    South Jersey
    You got it!
  13. Feb 24, 2008 at 2:32 PM
    Red-Paint
    Red-Paint Active Member
    David
    Dallas
    2017 AC TRD
    Painted grill and rear bumper, Removed all badges and stickers, Tint, OME lift TRD wheels and BFGs on order.
    I have a new 08 Prerunner.Wanted the biggest tire I could fit on the stock wheel.I buy alot of tires from Discount Tire.They took the time to mount and test fit a Michelin LTX M/S 275/70/16.Its big and looks great,rides great. Only 300 miles but does not rub at all.No lift or spacers. David I will up load a photo if someone wants.But I will need to weight for one of my kids to come home to do it for me... :confused:.Now I know why I had kids.All this stuff
  14. Feb 24, 2008 at 2:43 PM
    maverick491
    South Jersey
    Mounted and inflated that is a 31.3" tall tire, and it is 11.1" wide.
    While it is not quite half an inch wider than a 265/75/r16, it is about a half inch shorter, and I believe that the original poster was more concerned about height than width, but thank you. This is good information for anyone who is looking for a wider tire.
  15. Feb 24, 2008 at 5:59 PM
    ERdept
    Thanks for lookin out bro.
  16. Feb 22, 2009 at 9:45 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    I have an 07 pre runner w/o a lift and I just put 17in fj cruiser wheels with 265/70/17 and no rubbing at all. hope it helps
  17. Feb 22, 2009 at 9:52 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I have 20's w/o a lift on my truck with out rubbing. So 17's should be fine.
  18. Feb 23, 2009 at 6:12 AM
    The_Hodge
    SC
    and only a year late on these last 2 posts....should have made him wait for the info...lol
  19. Jan 9, 2021 at 12:40 PM
    CCrunner609
    CCrunner609 Member
    07 prerunner
    i am currently looking into 17" rims off a 2016 tacoma for my 07 prerunner. So everything should be good?
  20. Jan 9, 2021 at 1:36 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Let’s make it 11 years lol
    Yes, stick with 265/70R17 tires
    The_Hodge[QUOTED] likes this.
