Will 2 motorcycles fit in the bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fistgar, Jan 27, 2010.
  1. Jan 27, 2010 at 6:00 PM
    Fistgar
    Fistgar [OP] Off-Road Limo
    Chance
    Denver, Colorado
    2010 TRD Sport LB 4x4 MGM
    Satoshi grille, painted engine cover, 20% tint on windows, OME 3" Lift, TSB in the rear with ToyTec AAL, , tinted tails, Hella 500's. 1" body lift
    So I just purchased a 2010 4x4 dbl cab long bed Tacoma. In two weeks a buddy and myself are going to head south and take our sportbikes with us for some Florida riding. I am very curious if it is possible to fit two sportbikes in the back of the 2nd gen Tacoma Long bed and, if possible, got a pic or 2 of the bikes in the back? I really don't want to have to trailer them due to the length of the trip and the fact that my trailer sucks! If it helps, the bikes are a ducati monster and a Suzuki GSX600. I'm planning on cutting a piece of plywood to fit the front of the bed and installing some front motorcycle wheel chocks to keep the bikes verticle and stable. Any help or advice is greatly appreciated!
  2. Jan 28, 2010 at 12:02 PM
    Fistgar
    Chance
    Denver, Colorado
    I noticed today that I have two D rings mounted to the rear of the bed but none near the front. Is this an oversight when my truck was assembled or just something that I'm gonna have to add on myself? Just struck me as odd that they wouldn't place one in each corner of the bed.
  3. Jan 28, 2010 at 12:04 PM
    tacosteve
    tacosteve Active Member
    Milton, GA
    09 Tacoma 4X4
    3" lift and 33x12.50x20 toyo on Hoss wheels
    you will need to add the D rings if you want them, but when I put my bike in the back I just use the hooks in the bed rails. You may get two bikes in, but its going to be tough.
  4. Jan 28, 2010 at 12:07 PM
    Re8elmonk0341
    Re8elmonk0341 "Kill BABIES"
    m0nk
    Owasso, Oklahoma
    1st Gen. DC 4x4
    My buddy had a 05 Taco and we put my 05GSXR and his 03 in the bed. had to keep the tailgate down but we made it work somehow :D
  5. Jan 28, 2010 at 12:10 PM
    burtonboards32
    burtonboards32 Well-Known Member
    I myself would not recommend it. I had my R1 in the back and somehow the headboard of the bed actually cracked and split from top right down to the bottom of the bed. Also, I hope you are not going to Florida looking for twisties. You won't find them. All the roads are straight and flat. Save yourself the time and go to Deal's Gap.
  6. Jan 28, 2010 at 12:13 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    careful tying street bikes down to those movable hooks in the bed rails...i've heard of them coming loose before under the weight of street bikes vs. dirt bikes.
    but i think you'll be fine. i hauled dirt bikes in my short bed, hell ,even a golf cart (that was fuckin' interesting to say the least)
  7. Jan 28, 2010 at 12:13 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Careful using the bedrail cleats to secure the motorcycles. Definitely good as secondary secure points but I wouldn't rely on them solely. Those things aren't the strongest mounts in the world and I'd hate to see you lose your scoots if something lets loose.
    Those d-rings are bolted through to the frame. Add a couple up front and you'll be good. Also use wheel chocks to avoid having the bottom of the bikes slide out.
  8. Jan 28, 2010 at 2:17 PM
    Fistgar
    Chance
    Denver, Colorado
    I wonder how difficult it would be to mount the D rings in the front of the bed. I'm planning on securing the bikes with some wheel chocks mounted to some plywood cut to fit the front of the bed. If I go that route my main concern is securing the plywood cut-out since it would cover any D ring mounts. Perhaps I can drill some holes for the D rings, and mount the plywood using those holes. This would eliminate the need for the D rings since the wheel chocks I am using are T-shaped and have tie down spots on them for each bikes front end. Once I am done with this set-up, I can then remove the plywood cut-out with the chocks and install the D rings where I mounted the plywood. Sounds good in my head but wonder how it will work in real life ;)
    As for riding twisties in Florida... Yah not expecting to. We just want to ride and Deals Gap in the beginning of February is a death wish IMHO. We just want to relax and ride from Orlando to places like Daytona, Cape Canaveral, and perhaps Tampa. It's about the only place warm enough this time of year to ride so we are gonna do what we can to have a lil fun!
  9. Jan 28, 2010 at 2:31 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
  10. Jan 28, 2010 at 2:38 PM
    ekard
    ekard Well-Known Member
    San Jose, CA
    2011 DC SB 4X4 OR
    TRD Exhaust, Bilstein 5100's, Eibach coils, TSB Leaf pack, Toyota Bed Mat and D-Rings, Dakine Tailgate Pad, Wet Okoles, WeatherTech Floormats, PA15-TOY iPod Adapter, Goodyear Duratracs 265/75/16, SCS F5 wheels
    Definitely add new D-Rings to the front. You can either get the toyota D-rings and add them to the reccomended location, or you can just buy generic ones and throw them under the front bed bolts. Or both...
    Also, if you have time, go to your dealer and complain that you have a harsh ride with a lot of weight in the bed. They will replace your rear springs under warranty with a stiffer leaf pack. This is well discussed on this forum (search for TSB leaf pack). With two sport bikes in the back you will be a lot happier with the stiffer springs.
  11. Jan 28, 2010 at 2:38 PM
    ashjwilliams
    ashjwilliams Well-Known Member
  12. Jan 28, 2010 at 2:39 PM
    mjp2
    NJ
    Mount some anchors to the wood and strap down to that. As long as you cut everything so it conforms to the wheelwells you should have no issues with stuff sliding around. Between the wheel chocks and the straps pulling the bikes down the front should be plenty secure from a falling-over standpoint. Anchor the back of the bikes using the d-rings already in the truck. Use a couple more straps attached to the bed rail system up front to pull the bikes forward and you should be set.
    Obviously you'd want to use 3/4" or thicker plywood along with large thick washers on the bottom to keep the anchors from pulling through the wood. :)
  13. Jan 28, 2010 at 6:35 PM
    r0ss
    r0ss Active Member
    Ross
    SFO > LAX > AUG > ATL
    i have been dreaming of that ramp for a couple of years! i don't think it will do me much good... loading more then one bike in a short bed means the back wheels will be hanging out past the edge of the tail gate :(
    a golf cart? in a short bed? just when i was begining to think my trucks bed was pretty useless! i'd like to see some pictures of that.
  14. Jan 28, 2010 at 11:13 PM
    bryant8
    bryant8 Active Member
    Dallas
    2008 Black Double Cab Long Bed
    TRD CAI, eBay Fog lamps, LED bed lights, 12V bed plug
    You can fit them no problem. I throw 2 bikes in the bed to take to the track several times a year. I use my baxley wheels chocks, cyclesynches, and the added D-rings up front. Loading is a breeze.
  15. Feb 2, 2015 at 2:10 AM
    Brianshorti
    Brianshorti New Member
    Va
    Tacoma
    Factory
    Get two 2x10 boardsand scre them together and put eye let screws for tie downs and from the weight of front tires they wont move. Use the back tiedowns for the rears and use extra straps for the the tie down ls on the etract u will be good to go been a many of trips with my 2 r1's
