Will 20% tint give me problems at night?
Discussion in 'Detailing' started by Lou_kellis, Jan 2, 2019.
  1. Jan 15, 2019 at 1:12 PM
    #61
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Also, on our 4Runner, I had him do 15% on the front windows and just use whatever he needed to to match the rears. It's been good so far, I have zero issues with visibility.
  2. Jan 15, 2019 at 1:15 PM
    #62
    boostedka
    James
    NM
    Yeah if you want them to match that would be close. Usually tint shops can get it to match pretty close if that's what you want. On ext cabs, I've always been a fan of the back windows being darker for security purposes. This way I can keep items more out of sight and less likely to provoke a break in.
    On my 2000 I had, I got 15% on the front and also on top of the stock tint. This made the rears close to 5%. I liked that set up alot.
    I also had a '99 that I had 5% done all around including over the rear factory tint. That was dark AF! The rears were close to 0% LOL
  3. Jan 15, 2019 at 1:19 PM
    #63
    Greg617
    Greg617 Well-Known Member
    Greg
    New England
    2010 5-speed 4x4
    Dents and scratches... Fox 2.5 Factory
    I've got 35 on the front and something like 10-15 on the back/rear. Having the back darker will make the 35 up front seem darker IMO.
    However, i live in New England where its often cloudy and rainy, etc. In strong sunlight I sometimes wish I had 20. Never had an issue at night though unless my limo tint cap is on.
    (overcast photo example with my setup)
    boostedka likes this.
  4. Jan 15, 2019 at 1:21 PM
    #64
    boostedka
    James
    NM
    Good Point. Regional location definitely makes a big difference. Here in NM, we get sunlight 90% of the year. So 5% is pretty common here.
    @HSmith_11 Keep that in mind as well when you decide
  5. Jan 15, 2019 at 1:23 PM
    #65
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    With 20%, it is difficult to see when making a turn onto an unlit street. I have it on my truck and car... i do love it at all other times tho. If i was in the country alot i wouldn't go so dark....
    CusterFan likes this.
  6. Jan 15, 2019 at 1:24 PM
    #66
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    I'm pretty sure 20% would be good for my fronts. I'm mainly just trying to decide what I want with my rears. Also, what did you get do with the window on the very back? And I'm in VA, so I'm probably in the middle as far as weather conditions.
  7. Jan 15, 2019 at 1:26 PM
    #67
    boostedka
    James
    NM
    For the very back I've done just OEM tint, 5% on top of OEM tint, and 15% on top of OEM tint. I liked the 15% on top of OEM tint the best.
    danielsthomas57 likes this.
  8. Jan 15, 2019 at 1:43 PM
    #68
    HSmith_11
    Hunter
    Madison, Va
    I also read somewhere that someone suggested to buy some super cheap tint and decently apply it yourself. This would allow you to "test" it before you actually pay for the good stuff. Thoughts?
  9. Jan 16, 2019 at 10:10 AM
    #69
    boostedka
    James
    NM
    You can but then you have to remove the old tint. Tint shops will charge you more for this. My guy charges about $50. You can try to black trash bag trick to do this if needed. Just google it.
    Back in High School I tried tinting my windows on a '85 Ranger with the help of a friend. It came out like crap and when I went to have it professionally done, it was a bitch to remove b/c the cheap stuff uses crappy adhesives.
  10. Jan 16, 2019 at 11:24 AM
    #70
    HSmith_11
    Hunter
    Madison, Va
    What about static cling tint. I heard it has no adhesive so I would have to worry much about removable. Of course it would be crappy but it would give me a rough idea while being cheap. I would probably only keep it for a day or two.
  11. Jan 16, 2019 at 11:32 AM
    #71
    boostedka
    James
    NM
    That could work. The only thing is you need to do all the windows to really see the full effect of the tint. If you just do one window, the effects will be partially negated by light coming in through the others.
  12. Jan 16, 2019 at 11:54 AM
    #72
    HSmith_11
    Hunter
    Madison, Va
    I'll definitely do at least the front two
    boostedka[QUOTED] likes this.
  13. Jan 18, 2019 at 5:17 PM
    #73
    HSmith_11
    Hunter
    Madison, Va
    I got around to trying the static cling tint. I’ll start off by saying that it was only $10 so it was definitely worth it. The tint is super blurry and pretty blue. On the inside, it’s kinda annoying to look out the sides because of the blurriness. However, the darkness was no problem. It looks much better from the outside and definitely gave me a good idea of what my truck would look like if I actually got real tint.
    With that being said, I’m for sure sticking with 20% on the front, but I’m trying to decide whether or not I want to tint over the oem windows in the back. I got a quote from a local guy that does tinting and he would charge $70 for the front or $150 for the whole truck. My current thought is to just get the front done for now and add the rear later if I want it. Finally, is his price decent?
    Edit: pics added
    328F125D-76E8-46CA-80AA-26AA156201D3.jpg 1E5530AB-58C9-4895-90C1-5FF55F9612C7.jpg C377A57A-570F-480F-B622-C8CE425B5039.jpg
    Nevin likes this.
  14. Jan 18, 2019 at 5:22 PM
    #74
    boostedka
    James
    NM
    Sounds like a fair price. My guy would normally charge $50 and $120 for that. But he’s also self employed and runs his shop on the same property as his house. So he has a lot less overhead.
  15. Jan 18, 2019 at 5:22 PM
    #75
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Nice lunar mist! :thumbsup:
  16. Jan 18, 2019 at 5:26 PM
    #76
    HSmith_11
    Hunter
    Madison, Va
    This guy is also a smaller business. He might have a building at this point though.
    Thanks!
  17. Jan 22, 2019 at 4:02 PM
    #77
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I had my truck done last month 5 windows for $175.00. I have 20% on the front 2 and 35% over the factory privacy glass on the back 3. They all match perfect as the tint guy put the meter on them when he was finished. And it showed 14% VLT (visible light transmission) which is illegal here in Illinois. LOL
  18. Jan 27, 2019 at 6:28 PM
    #78
    runner05
    runner05 Well-Known Member
    Karl
    My truck has 20% tint and it is hard to see the curbs at night sometimes.
  19. Feb 10, 2019 at 8:24 AM
    #79
    VinDieselJetta
    VinDieselJetta Well-Known Member
    FL
    2016 TRD Off-Road 4X4
    I have limo tinted my vehicles for years, night visibility is definitely affected. Love the daytime darkness and privacy tho
  20. Feb 14, 2019 at 2:47 PM
    #80
    Mintswitch
    Mintswitch Well-Known Member
    2018 DCSB OR AT Blazin'
    Yes, 20% tint will give you issues at night, but it is really nice to have on bright sunny days.
    I probably won't tint my recently purchased Tacoma because the night driving with 20% really did annoy me on my previous vehicle, and I honestly don't think 35% makes a big enough difference for me.
