Will 2004 4runner wheels fit a 2005 sequoia?
Discussion in 'Wheels & Tires' started by lepedog23, Jan 26, 2012.
  1. Jan 26, 2012 at 9:49 AM
    lepedog23
    lepedog23 [OP] Taco Rookie
    Frank
    Huntington Park
    Wrecked 2002 4Runner 4x4 trying to rebuild ***Sold2001 DC Tacoma. Stock. Salvage Title MOD.
    Wrecked 2002 4Runner 4x4 ***Sold 2001 Tacoma, Salvage Title MOD. ***Sold 2010 Tacoma doublecab prerunner
    i bought some 2004 4runner wheels for my 2005 sequoia. My sequoia came with aftermarket 20" wheels that i like but it makes ride bumpy.
    So i picked these wheels up and i mounted on sequoia, without tires, since i have yet to buy, and they fit since its same bolt pattern.
    I was looking at offset info and i think i read that sequoia is 16mm offset and the 4runner wheels i bought are 30mm offset.
    im going to be putting 265/70/16 tires. sequoia originally comes with 265/65/17.
    Do you guys think i will have a problem with rubbing?
  2. Jan 26, 2012 at 9:51 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    They both have the same bolt pattern and are listed as "medium offset" so you should be alright. You'll want to confirm the offsets or backspacings to be sure.
  3. Jan 26, 2012 at 8:06 PM
    lepedog23
    Frank
    Huntington Park
    The offset on oem sequoia wheel is 16mm on the runner wheels its 30mm. Offset.
  4. Jan 27, 2012 at 5:47 AM
    TexasTacoma37
    What is the width of each rim? That way we can compare how much each will stick out.
  5. Jan 27, 2012 at 11:15 AM
    lepedog23
    Frank
    Huntington Park
    i measured the runner wheels and they are 16x7 30mm offset. i dont have oem sequoia wheels but i think i read they're 16x7.5 16mm offset.
  6. Jan 27, 2012 at 11:18 AM
    TexasTacoma37
    Alright that gives the 4-runner wheels 5.25" backspacing and the sequoias approve 5" BS. So the sequoia wheels will sit 0.25" further from uca on the inner edge, and sit out 0.75" further at the outside edge.
  7. Jan 27, 2012 at 12:02 PM
    lepedog23
    Frank
    Huntington Park
    so do you think 265/75/16 or 265/70/16 will rub on turns? im keeping same width on tires but want to go up one/two sizes.
    ive read on toyotanation that guys go up to 265/70/17 which is a 31.61" tire with oem with of 10.43.
    if i go up to 265/75/16 its a 31.65" tire with oem with of 10.43 as well.
  8. Jan 27, 2012 at 12:10 PM
    lepedog23
    Frank
    Huntington Park
    worst case scenario i can just buy some spidertrax right
