Will 2010 TRD 17" rims fit on my 2001 TRD?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lawman, Nov 11, 2010.
  1. Nov 11, 2010 at 5:54 PM
    Lawman
    Lawman [OP] Active Member
    Jacksonville, FL
    01 Tacoma SR5 TRD
    3.5 RevTec Suspension Lift, Gray wire Mod, Snobord552's light bar, HID conversion kit, 3 SRS Off-Road lights, Dogmod
    Hey will the stock 2010 TRD 17" rims fit on a 2001 TRD, that has 16" Rims?
  2. Nov 11, 2010 at 6:00 PM
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    I sold my 17 inch wheels to a guy that has a 02 taco so i would say yes
  3. Nov 11, 2010 at 6:11 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  4. Nov 11, 2010 at 9:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yes, but...
    The stance will be narrower. Those wheels don't stick out as far as the stock wheels.
  5. Nov 12, 2010 at 8:00 AM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    Itll fit, I just put some on, but the backspacing is higher so the wheel is sucked in more than the stock 1st gen wheel. At full lock either way I get rubbing too so I'm going to put some spacers on the front. Pretty much every Toyota 6 lug wheel will fit the Tacoma. Its the backspacing that will get ya.
