Will 2018 Frames get added to the rust list?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by soggyBottom, Oct 19, 2019.
  1. Oct 19, 2019 at 5:32 PM
    #41
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    some werent i have an 1987 car that was dipped in galvanized and still looks great.
    Gerard6778[QUOTED] likes this.
  2. Oct 19, 2019 at 5:43 PM
    #42
    jws6295
    jws6295 Well-Known Member
    Central PA
    2016 SR5 double cab long bed
    I have yet to get a letter for my frame. But I’m sure with some time I’ll receive one since I live in Central Pennsylvania and we have some crazy salted roads in the winter.
    But I’m with everyone that has mentioned simply just washing your undercarriage will help. My family has a auto repair shop which I work in and I can’t count the amount of frames we see anymore that are rusted through. Might sound crazy but I feel that even has simply just wiping off your frame with an oil here and there helps. Sounds old fashioned but I feel ATF sprayed on with a garden sprayer works well. But not very eco friendly.
    It’s not a auto make issue, it’s all how you take care of your vehicle. But with time no matter what you do steel will rust so Even Toyota’s crappy rubber coating is better than nothing.
    stun gun likes this.
  3. Oct 19, 2019 at 7:25 PM
    #43
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    True, I should have set “most”. I had a ‘78 Porsche that was galvanized.
    auskip07[QUOTED] likes this.
  4. Oct 19, 2019 at 9:24 PM
    #44
    White Stripe
    White Stripe Member
    Most of the 3Rd Gen frames look to have nearly the same construction type as the 2nd Gen Tacoma. So they should rust similarly then as the 2nd gens did. Washing the underside will help, but due to the type of c-channel frame they use, it's unlikely you'll be able to wash out all the road salt. However I have noticed either 2019 or 2020 models-cant remember which-have additional measures taken that should eliminate rusting so bad.
  5. Oct 20, 2019 at 12:58 AM
    #45
    jcos112
    jcos112 Well-Known Member
    How many people is “so many people”?
    Hundreds, thousands, hundreds of thousands, millions?
    Seriously flawed logic.
    Think about it.
  6. Oct 20, 2019 at 3:13 AM
    #46
    soggyBottom
    soggyBottom [OP] Well-Known Member
    Black DOG Lila and stun gun like this.
  7. Oct 20, 2019 at 3:57 AM
    #47
    motofish84
    motofish84 Well-Known Member
    Tyler
    I live in Wisconsin. The amount of salt that they use on the roads here would trash any vehicle driven on them. I hate rust...it has been the demise of many of my vehicles. My 2018 Tacoma came from Washington with 25k miles and the under body is extremely clean. I'd like to keep it that way.
    I am planning on driving it in winter but garaging it when it's not driven. I worked in a dealership for 15 years and you can spot a 10 year old garage kept car vs. one that was not pretty easily. They corrode much more quickly and components wear out quicker as well. Brakes, belts boots, bushings.....that's a lot of b's.
    Anyhow, I'd like to keep this truck as rust free as possible. I typically wax my cars 2 or 3 times per year and get a good coat in the door jambs and other nooks and crannies on my pre-winter wax. I have never undercoated any vehicle. Is it easy enough to do at home? I'd prefer something that isn't a waxy film...is that my only or best option?
    I usually try and do under body flushes anytime I run my vehicles through the touch less wash and I want to get the Ryobi water broom / under body cleaner for home washes.
  8. Oct 20, 2019 at 7:36 AM
    #48
    MyWifesTaco
    MyWifesTaco Well-Known Member
    OKC/Southern Colorado
    2019 Tacoma Cavalry blue 4cyl access cab 4x4
    TRD pro grille .
    Has anyone noticed that the 19 frame has the " black rubber" silicone style treatment on the frame where the c channels are two layers ..... In my opinion this only traps water and salt in without allowing it to drip out when washed
    And I have mud / rust OCD so I wash out under all my trucks more than I wash the topside
  9. Oct 20, 2019 at 7:46 AM
    #49
    Gerard6778
    Gerard
    2015 TRD Sport
    Sure :jerkoff:
  10. Oct 20, 2019 at 9:55 AM
    #50
    jcos112
    Keep using the “make it up as you go along” method. It works for you.
  11. Oct 20, 2019 at 10:07 AM
    #51
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If you have a heated garage you’ll be better off leaving the truck outside all winter. Putting a vehicle back in a warm garage after being out in the cold and covered in frozen ice/salt grime allows that crap to melt and migrate into all the nooks and crannies of the frame. Leave it out in the cold and take it to a hot water pressure washer every once in a while to clean it all off.
    Gerard6778 likes this.
  12. Oct 20, 2019 at 10:27 AM
    #52
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    That guy should be spraying the pizza sauce off the side of his vehicle.
  13. Oct 20, 2019 at 10:34 AM
    #53
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Agreed, and the more the temperature increases, the more active rust [chemical reaction between iron and oxygen, salt makes it go nuts] becomes. At zero, nothing is basically happening, warm it up to 30, 40, 50 degrees F and it really goes to town. Those are the days when you want to get the salt and garbage off your vehicle.
  14. Oct 20, 2019 at 11:14 AM
    #54
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Many people don't wash their cars. Many who do don't ever spray below the shiny parts. I would bet these are (most of) the frames that rust to shit.
    I've been looking at Jeeps recently. They rust as badly as any Tacoma.
  15. Oct 20, 2019 at 11:16 AM
    #55
    soggyBottom
    I hadn't considered this and it looks like you're right.
    https://www.engineeringtoolbox.com/oxygen-steel-pipe-corrosion-d_1170.html
  16. Oct 21, 2019 at 4:41 AM
    #56
    motofish84
    Tyler
