will 255/85/16's fit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by waller24, Apr 21, 2010.
  1. Apr 21, 2010 at 6:30 PM
    waller24
    waller24 [OP] Well-Known Member
    Alabama
    2007 Tacoma DC TRD 4x4 impulse red
    usa spec iphone adapter pa15, 1.5 coil lift, warn transformer, warn 8000 winch, UWS black short bed tool box, Grey weather tech mats, mounted streamlight stinger xt, rbc 4x4 light Alignment cam .15 .16 cast 2.24 2.5
    will 255/85/16 km2's fit with stock rims with a 1.5 in front lift without rubbing issues. I currently have 265/75 TA KO's and between them would be about a 1.5 in difference in tire height
  2. Apr 21, 2010 at 6:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You will probably still have rubbing. Those are 33's.
  3. Apr 22, 2010 at 12:18 AM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    from what I have read, you will have rubbing issues
  4. Apr 22, 2010 at 12:22 AM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Definitely have rubbing issues
  5. Apr 22, 2010 at 6:15 AM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    I was going to ask this myself except with 255/80/17. I think at the very least the mud flaps would have to go.
  6. Apr 22, 2010 at 1:11 PM
    RSG
    RSG Member
    Iraq...for now
    08 DoubleCab Off-road
    4xinnovation sliders
    YES! That size will fit with NO TRIMMING for normal driving and mild to moderate wheeling, but my experience is with the Cooper Discoverer ST tires. KM2s may not fit.
  7. Apr 22, 2010 at 2:12 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Do you have any pics? Im curious.
  8. Apr 22, 2010 at 8:26 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    km2 255/85/16s are going to rub, you will need to remove the mud flap, trim some plastic at the bottom rear end of the wheel well and mod the pinch weld and possibly make your bump stops a little longer. How much depends on how much and how hard you use it off road. even then you may need a good alignment guy to get the wheel forward in the well to keep you off the cab mount. You may get away without any of this if you stay on the street but even then you will be rubbing here and there on a daily basis. Good luck.
  9. Apr 29, 2010 at 12:16 PM
    customz
    customz Well-Known Member
    09 prerunner access 2wd 4cyl 5sp
    how about with the 5100s at 2.5 and the tsb on stock wheels?
  10. Apr 29, 2010 at 12:20 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    then they will fit, with minor rubbing if any.
  11. Apr 29, 2010 at 12:29 PM
    customz
    good to hear. I want to maintain at least 20 mpg though. I'm at 22.2 over the last 50k on 245s and 265s. So I am stuck with leaving it stock and putting some street tread michelins 265/75-16 and keeping it reliable or start messing with lifting the front end, swapping gears, shocks etc. I want this truck to last 250k and am wary of creating unecessary probs, but want it to look cool too.
    what you guys think about leveling kits and reliability? my local dealer will install it all and probably do the gear swap
  12. Apr 29, 2010 at 12:35 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Your gona drop 2 mpg for sure turning the heavier tire if you stay stock. What gear swap are you going to?
  13. Apr 29, 2010 at 12:37 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    ^yep, I was considering the 255's to go with my small lift, but I just cant take that hit in MPG so im going with the 265/75's.
  14. Apr 29, 2010 at 2:29 PM
    customz
    4.56 or 4.88 depending on strength of pinion, cost and needed mods. You still think mileage will drop once I do gears. Remember the speedo will read slow so the difference needs to be adjusted to calculate true mpg drop.
  15. Apr 30, 2010 at 7:53 PM
    customz
    bump
