Will 265/65/R17 tires rub on TRD Pro wheels?
Discussion in 'Wheels & Tires' started by TedTRD, Dec 31, 2023.
  1. Dec 31, 2023 at 7:59 AM
    TedTRD
    TedTRD [OP] Well-Known Member
    Charles
    2023 Tacoma TRD
    Need help from the wheel and tire experts. Have a 2023 TRD Sport with 5’ bed and OEM mud flaps which I want to keep in place.
    Really like the ride of my OEM Firestone 265/65/R17 tires and want to keep them. Also like the look of the 17x7 TRD Pro wheels from BAM: PTR20-35110-BK.
    I understand moving the tires to the TRD Pro wheels will retain the same tire diameter and circumference. But, I think the factory OEM Sport wheels have a 30mm offset while the TRD Pro’s are 4mm offset. Am I thinking correctly that the 26mm difference in offset will pull the wheels inward toward the hub 1.024 inches?
    Questions are:
    1. Will this cause any tire rubbing (even at hard lock turns) on the inner suspension or flares/mud guards?
    2. Will this setup make the tires look too drawn in or funny?
    3. What about alignment and ride quality?
    if anyone has this exact setup, photos here would be greatly appreciated.
    Cheers and Happy New Year!
  2. Dec 31, 2023 at 8:05 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Going to the sema wheels moved the tire centerline outwards by 26mm. Towards the fender opening. This is actually what causes rub because of the new larger arc the wheel swing in on turns.
    That said, 265/65R17 is no problem on the sema wheels. I ran that combo for a while. When I had 265/70R17 tires on the same wheels, I would hit the factory flaps on turns at speed or on turns with bumps.
    I wanted to step up the tire size without rubbing so I traded the Sema wheels for Sport wheels. I now have 255/75R17 (32.1”) tires and no rubbing, with factory 30mm offset sport wheels.
  3. Dec 31, 2023 at 8:07 AM
    Bishop84
    Bishop84 Well-Known Member
    No it will fit fine, this is one of the most common upgrades people do.
    Just bolt them on and go.
    Issue you'll run into is transferring the TPMS sensors, they don't unbolt from 2023 models, so you'll likely need new tpms. I havent removed any yet, but they are one and done if I recall.
  4. Jan 2, 2024 at 7:13 PM
    TedTRD
    Charles
    2023 Tacoma TRD
    Thank you for the replies.
