Will 265/65r17 tires impact performance on 4cyl Tacoma ?
Discussion in 'Wheels & Tires' started by Branmar96, Dec 19, 2020.
  1. Dec 19, 2020 at 12:25 PM
    Branmar96
    Branmar96 [OP] New Member
    2020 Tacoma sr5
    I recently purchased a 4 cyl 2019 Double cab Tacoma with the TSS off-road package, basically comes with 17 inch blacked out rims, blacked out logo, blacked out grill etc, my question is will this bigger size of tires and rims cause the motor to strain more and possibly cause premature wear and tear on my motor or transmission? It runs fine to me but maybe in the long run ? The tires and rims came standard, tire size is 265/65/17r
  2. Dec 19, 2020 at 12:29 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Any larger or heavier tire will cause a performance difference. Huge tires may have an impact on the motor and tranny over time. The size you are referencing is actually the factory size.
  3. Dec 19, 2020 at 12:35 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Mileage will suffer. I lost 30% going from 245s to 265s, both P metric mild all terrain.
  4. Dec 19, 2020 at 12:37 PM
    Rushed Virus
    Rushed Virus Active Member
    Chandler
    Houston
    2019 quicksand tacoma OR
    Tint, backflip bed cover, winjet taillights, trd pro grill with raptor style lights, 6112s up front and 5160s with icon aal rear, SPC UCA's, 275/70r17 ko2s dark bronze ray 10s, c4 hybrid front bumper, x4 baja designs squadron sports, baja designs 30in s8 light bar.
    If you change the tires or rims in any capacity you'll mess up your speedometer and affect performance.
  5. Dec 19, 2020 at 12:53 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    That is NOT a big tire. It is 1/10" taller than factory and 3/4" wider than the tires that came on my truck from the factory. You'll be fine.
    0xDEADBEEF and Wulf like this.
  6. Dec 19, 2020 at 1:03 PM
    T4RFTMFW
    No.
  7. Dec 19, 2020 at 1:06 PM
    Rushed Virus
    Chandler
    Houston
    Changing rim size, tire size or both WILL change it in some capacity. You trolling right?
  8. Dec 19, 2020 at 1:10 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    This. Unless they're a really heavy tire or rim, the difference is negligible from the factory size. Nothing to worry about @Branmar96
    https://www.tacomaworld.com/tirecalc?tires=245-75r16-265-65r17
  9. Dec 19, 2020 at 1:22 PM
    T4RFTMFW
    You said changing them in any capacity will “mess up” the speedometer and affect performance.
    That is false.
    I can add lighter wheels and less rolling resistance tires with the same overall circumference and have no issues with speedometer and have a performance benefit. Or I can get heavier wheels, taller, wider, and heavier tires and have a negative experience. But saying that any change in any capacity will cause the same overall affect is a generalization that isn’t accurate.
