Will 265/70/18 be right?
Discussion in 'Wheels & Tires' started by Wallsjm1, May 27, 2013.
  1. May 27, 2013 at 4:37 PM
    Wallsjm1
    Wallsjm1 [OP] Well-Known Member
    Justin
    Tennessee
    2007 Speedway Blue 4x4 TRD-Off Road
    XD Rockstars 18's, Nitto Terra Grapplers, Billies all the way around, set to 3 inches, AAL, Chrome push bar, Westin step bars
    Is 265/70/18 gonna be big enough for my three inch lift I have all this stuff on order and I'm affraid the tires will be to small. I thought that 265/70/18 was almost a 33 inch tire and I'm hoping that is true. Any advice?
  2. May 27, 2013 at 4:54 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I'm sure it's gonna look awesome! 33" tires is usually the biggest they recommend on our trucks with a 3" lift. Your 265/70/18 comes out to 32.60
    So basically your gonna be running 33's with a 3" lift.
    I have 30.5" tires and they look small on my 3" lift. The extra 2-2.5 inches is gonna make a huge difference in looks once I get my 255/85/16 bfg km2
    Put some picks up when you get the new "shoes" on
  3. May 27, 2013 at 5:08 PM
    Wallsjm1
    Justin
    Tennessee
    But see I have 265/70/16 on my tacoma now, I didn't know that going from a 16 inch wheel to a 18 made my tire taller
  4. May 27, 2013 at 8:54 PM
    Mainmoe02
    Moe
    Austin, Texas
    Yeah I didn't get it at first either but it does. If you search tire size calculator you can just punch in the numbers and it'll calculate your tire size in inches.
    Or
    Use this method: ex: tire size is 265/70r16
    (265 x .70) x 2
    ----------------- + 16 = 30.6
    25.4
    The way I look at it is, if they take away rubber in the center for a bigger rim then they add it on the outer. If you want to stay around the same height then maybe 265/60/18 (if that's available?)
  5. May 28, 2013 at 7:13 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    That's a great tire size choice for a 3" lift. You're good to go. Any larger and you'll need to do more chopping and trimming.
