Will 265/75/16 fit with Eibach lift springs?
Discussion in 'Wheels & Tires' started by jeffcos, Jan 25, 2011.
  1. Jan 25, 2011 at 5:22 PM
    jeffcos
    jeffcos [OP] Active Member
    Jeff
    Massachusetts
    09 4x4 AC SR5
    14" Shorty Antenna, Mud Flaps removed, K&N drop-in, 265/75/16 Dynapro ATM's, Transmission TSB, Center Console Lock Mod, Toyota All-Weather Mats, Debadged
    Hey, this is my first post on TW and I just want an opinion on tire sizing.
    This will be my first real mod to my taco (besides some TSB's and accessories); I'm getting the Toytec/Eibach 1.6" lift springs to put over the stock shocks (for now, until i can find the 5100 billys in stock somewhere) and also getting new tires on the factory 16" steel wheels (hankook dynapro atm). I wanted to make sure I can fit 265/75's with the lift of the eibach springs.
    Thanks!
  2. Jan 25, 2011 at 5:39 PM
    bobfm10350
    bobfm10350 Well-Known Member
    Deric
    Austin Texas
    06 PreRunner TRD Off Road
    Access Limited Tonneau, Hawk LTS Brake Pads, SP Performance Slotted Rotors, Goodrich G-Stop Brake Lines, Thule Roof Rack, Bilstein 5100s Front and Rear, Eibach Coil Springs, Cabela's Floor Mats, 265-75-16 Duratracs, Fog Light Anytime Mod, D-Rings Mod, USA Spec PA15 TOY Ipod Adapter, Gorilla Lock Nuts, K&N Drop-In Air Filter, Wet Okole Seat Covers Front & Rear, Toytec 1.5" AAL, Viper 5901 Car Alarm
    Welcome to TW!
    I currently am running 5100s set at zero on eibachs with 265-75-16 Goodyear Wrangler Duratracs with no problems at all. Technically you should be able to run those tires stock without the eibachs too. You might want to wait for some 5100s to come in stock before you mount the eibachs on the stock springs that way you dont have to install the springs on again which is kind of a hassle.
  3. Jan 25, 2011 at 5:47 PM
    bgbdwlf
    bgbdwlf Well-Known Member
    surprise,az
    08 PreRunner Off Road
    bone stock for now
    this is mine with 5100's @.85 and eibachs running a 265/75/16 Dynapro's just to give you an idea of what it looks like when you get your 5100's
  4. Jan 25, 2011 at 5:54 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I am running the same size w/ my ebiach and 5100's. :D
    wity hancooks
  5. Jan 25, 2011 at 5:57 PM
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    if thats with that....i cant even imagine what 4in's will look like with my spindles......im gona hav to get new rubbers cuz with 2.5 of lift those look small and im running the same size tire:(
    the again its only a 1.5in more.......back to the drawing board :D
  6. Jan 26, 2011 at 4:43 AM
    bgbdwlf
    surprise,az
    bone stock for now
    with 4" they would look tiny, i could have went with 285's but didn't want to do any cutting and stuff and with only a 16" rim it's not that bad. if i would have went with a bigger rim i think it would have looked kinda fugly.
  7. Jan 26, 2011 at 11:03 AM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    265/75/16's will fit under stock suspension as said above. Here is my 5100/Eibach setup.
