Will 265/75R/16 rub 2013 Access Cab
Discussion in 'Wheels & Tires' started by ktang, Mar 24, 2013.
  1. Mar 24, 2013 at 6:26 PM
    ktang
    ktang [OP] Member
    Hi All, I'm planning replace my oem 245/75R/16 to a 265/75R/16 Hankook Dynapro ATM , will this tire rub any or mud guard? Thanks in an advice for any input.
  2. Mar 24, 2013 at 6:27 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Should be fine on stock wheels
  3. Mar 24, 2013 at 6:34 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    wont rub
  4. Mar 24, 2013 at 6:54 PM
    OZ-T
    Peter North
    British Columbia
    Wasn't his caster totally fubar though
  5. Mar 24, 2013 at 6:59 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Should be good. Caster will play a part in it though. I'm running them on mine and it was stock when I got them.
  6. Mar 24, 2013 at 7:07 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2015 DCSB OR Auto Silver Sky 4x4 / 2017 4Runner Premium
    I run them on my double cab. No problem. Stock wheels. Should be the same.
  7. May 3, 2013 at 2:12 PM
    JpAdct
    JpAdct Well-Known Member
    PB County, FL
    2003 Tacoma ExtCab
    My 265/75-16 Duratracs didn't rub until I put wheel spacers on. Lifted about 3" in front and it still rubs with the wheel spacers in. Going to take spacers back out and see how it does then. I haven't been able to add enough extra clearance with caster yet either. I'm at 3.3 and 3.7 and still rubbing, but it does appear to be due to the wheel spacers.
