Will 275/70-17 fit stock?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Airborne daddy, Jan 2, 2016.
  1. Jan 2, 2016 at 4:39 PM
    Airborne daddy
    Airborne daddy [OP] Well-Known Member
    Jamie
    knoxville, tn
    2016 Trd sport
    I have a 16 Sport Trd with the 17 inch wheels and 265/65-17 tires. Considering going with Firestone Destination AT 275/70-17's. The tire calculator shows the Firestone's to be 1.5" inches taller.
    Would that fit with the stock setup? Or how much lift would be required to clear? I don't doany crazy wheeling or anything. Appreciate any advice.
  2. Jan 2, 2016 at 8:45 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Maybe but it will be tight , likely rub the flaps anyway
    I only have about 5/8" of clearance to my UCAs too
  3. Jan 2, 2016 at 10:20 PM
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    ‘24 LC250 First Edition, ‘25 TRDOR 6MT, 2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    I just fitted this size tire to my truck yesterday, but on 4Runner TRD Pro wheels. I'm not sure, but I don't see it working with the stock sport wheels. They will most likely rub on the UCA and possibly hit the frame on full lock. I heard a slight rub once since I put them on, but that was when I was flexing close to full lock, and it was just barely. I'll be able to get by like this now until the lift comes in, whenever that may be
  4. Jan 3, 2016 at 1:50 AM
    OZ-T
    Peter North
    British Columbia
    I have Sport wheels
  5. Jan 3, 2016 at 5:54 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    I can verify that LT265/70r17 do fit if that gets you closer
    Airborne daddy[OP] likes this.
  6. Jan 3, 2016 at 12:25 PM
    Airborne daddy
    Jamie
    knoxville, tn
    2016 Trd sport
    Ok, thanks. Sounds as though it may require some lift. The tire calculator says .5 inch wider. So that would be 1/4" wider on each side of the tire. That may clear the UCA.
    Maybe Bilstein's on the front and a 1" bolock in the rear may do it?
  7. Jan 3, 2016 at 12:39 PM
    TacoRat
    TacoRat Well-Known Member
    SoCal
    2012 Tundra 4x4
    people here running 275/70/17 KO2 with trd pro wheels on stock suspension. No issues .Sport and TRD off road 4x4.
  8. Jan 3, 2016 at 12:42 PM
    redbull9944
    Southwestern PA
    Not so much lift as less backspacing on your wheels. I'm not running any lift and the tires fit great. It fits because I'm running the TRD Pro wheels
  9. Jan 3, 2016 at 12:44 PM
    Airborne daddy
    Jamie
    knoxville, tn
    2016 Trd sport
    So the TRD wheels give a bit more backspacing over stock?
  10. Jan 3, 2016 at 12:52 PM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    You shouldn't go by the width of the tread section. Look up the specific tire and the manufacturer's width spec. Some tires have wider width than their tread rating would lead you to believe.
  11. Jan 3, 2016 at 12:56 PM
    Airborne daddy
    Jamie
    knoxville, tn
    2016 Trd sport
    Will do. I see what your saying. Specs can vary despite numbers being the same. Thanks.
  12. Jan 3, 2016 at 12:58 PM
    JoeRacer302
    Joe
    Pasadena, CA
    Yea, there are just other factors than the tread width that contribute to tire width. This is especially true of tires with big lugs on the sidewall like a Duratrac or KM2 compared to a standard A/T with no sidewall lugs.
  13. Jan 3, 2016 at 1:00 PM
    redbull9944
    Southwestern PA
    Yeah. I believe they are -12mm instead of -25mm
  14. Jan 3, 2016 at 3:08 PM
    Airborne daddy
    Jamie
    knoxville, tn
    2016 Trd sport
    I've had my peeps on those TRD wheels and they are nice. Those may be in order. Damn, this is getting expensive! No more guns for a bit.
    kylepre25 likes this.
  15. Jan 3, 2016 at 7:25 PM
    redbull9944
    Southwestern PA
    Haha! Thank goodness I got all my gun purchases done early last year. I should be good... for a little bit anyways ;)
  16. Jan 4, 2016 at 4:00 AM
    smugly
    Doug
    Are you ever really done, purchasing firearms and firearm accessories :infantry:
  17. Jan 4, 2016 at 4:46 AM
    Airborne daddy
    Jamie
    knoxville, tn
    2016 Trd sport
    It never stops-putting together another AR. And all them pesky little bullets.
  18. Jan 4, 2016 at 7:12 AM
    smugly
    Doug
    I usually have at least three projects going in anytime. I guess that's the advantage to having a shooting range on your property
  19. Jan 4, 2016 at 6:46 PM
    dontstealmyride
    dontstealmyride Well-Known Member
    SLC, UT
    2016 TRD sport MGM sortbed
    Not the stock TRD wheels. The aftermarket TRD pro rims. If you use stock rims you need wheel spacers to make your tires stick out past the fender. Or get rims that are offset to stick out farther. The upper control arm will rub on the inside of the tire where the lettering is, if you go wider tire on stock rims.
  20. Jan 6, 2016 at 3:22 PM
    kylepre25
    kylepre25 Active Member
    Kyle
    Cleveland, OH
    16 trd sport dbl cab
    Rough Country 3inch lift, TRD wheels, LT265/70/17 BFG all terrain ko2s, 20% tint on front, 5 percent back and rear windows,
    So what size spacer do you think would be needed if I used stock TRD Sport wheels?
