Will 275/70/17 tire fit on spare steel wheel?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoroach, Jan 6, 2018.
  1. Jan 6, 2018 at 6:36 PM
    Tacoroach
    Tacoroach [OP] Well-Known Member
    Vancouver, BC
    2017 DCLB
    I mean if the spare steelie is wide enough to accommodate 275/70/17 or even 285/70/17 tire? Thanks
  2. Jan 6, 2018 at 6:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    Isn't the wheel the same dimensions as the ones on the ground?
  3. Jan 6, 2018 at 8:05 PM
    Tacoroach
    Vancouver, BC
    2017 DCLB
    I only know that it's the same 17" diameter
  4. Jan 6, 2018 at 8:11 PM
    Bishop84
    Bishop84 Well-Known Member
    If you're worried about fit run a 255/80R17 on the spare. Almost identical diameter, just narrower. Plus its cheaper, no reason to spend big bucks on a tire, just to mount on a steel rim and hide it.
  5. Jan 6, 2018 at 8:20 PM
    Tacoroach
    Vancouver, BC
    2017 DCLB
    Thanks that's actually a good idea. I was also thinking to put some P rated or standard load tire cause it's cheaper on steelie. Or used. Size is critical though
  6. Jan 6, 2018 at 8:24 PM
    Tacoroach
    Vancouver, BC
    2017 DCLB
    Actually 255/80/17 is 33.06" vs 275/70/17 is 32.15. Almost an inch. Don't know if that can be a problem
  7. Jan 7, 2018 at 4:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    Use the tire calculator to figure out something closer if you wish.
    Like 255.75.17
    As far as knowing the wheel size, it should be stamped on the edge of the wheel. My guess is it's the same dimensions as the wheel on the ground.
  8. Jan 7, 2018 at 5:00 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Yes. The only thing that is important is the wheel diameter (the 17).
    Those tires will not however, fit in your spare spot without modifications.
  9. Jan 7, 2018 at 11:03 AM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Theres a couple brackets you can cut off and bend out of the way and fit 33s. Its the tire diameter that matters not rim...255/80/17 are great tire size but your options are a bit limited for choices. Also the spare steel rim has the stock offset so if you put a 285/70/17 on there it might rub your UCA so you might only be able to use it on the rear..
