Will 275/70/r17, 0 offset rub?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by toker808, Oct 18, 2019.
  1. Oct 18, 2019 at 3:01 PM
    toker808
    toker808 [OP] Active Member
    2019 TRD Sport 4x4
    Currently running stock suspension but plan on getting 2” Lift soon and want to upgrade my tires to 275/70/17 ko2’s. Will I get any rub or should I be g? Gonna be wrapped around method 312’s 17x8.5, 0 offset. Any info would help, and if you have any pics of this setup , feel free to post! Thanks in advance fam.
  2. Oct 30, 2019 at 2:13 AM
    TacomaOC714
    TacomaOC714 Well-Known Member
    2015 Tacoma TRD OR 4x4 silver sky metallic
    You will need to remove the mud flaps and you might rub at full lock, but just driving around town with a 2", you should be fine. Body mount chops and alterations to the wheel well are for 285 and up as well as a big negative offset. With 0 you should be ok
  3. Oct 31, 2019 at 7:54 PM
    toker808
    2019 TRD Sport 4x4
    Awesome. Thanks for the response bro!
  4. Oct 31, 2019 at 8:06 PM
    RHelton10
    RHelton10 Well-Known Member
    Atlanta, GA
    '16 DCLB MGM TRD Sport 4x4
    Predator bars, Revolver X2 tonneau cover, SwingCase tool box, Husky mats, HID conversion Fuel vapor 17” wheels, 2” front /1” rear lift with Bilstein 5100’s, 285/70R17 Nitto grappler 2’s
    For what it’s worth I just did a 2” lift and put 285/70R17’s on Fuel Vapor 17’s with what I think is a 1” offset. No rubbing, so with the 275 I think you’d be ok as well. Worst case scenario, if you do rub add a 1” spacer to your wheels to create some offset.
  5. Oct 31, 2019 at 8:20 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    If you don't turn, you won't have a problem. Good luck with that.
