will 285/75/16's fit
Discussion in 'Wheels & Tires' started by xGManx, Mar 28, 2011.
  1. Mar 28, 2011 at 9:59 AM
    xGManx
    xGManx [OP] Well-Known Member
    Garrett
    South
    06 DC LB
    black rims, blacked out grille, blacked out exhaust tip, 5100's 1.75" with 2" rear block, pioneer head unit
    i have a DC LB with 5100's at 1.75" and 2" rear blocks, im running the stock off road rims (16") and 265/70/16 cooper discoverer ATR's, could i fit 285's probably the same cooper tire or BFG all terrains, with the amount of lift that i have? or would i have to trim from rubbing
  2. Mar 28, 2011 at 10:02 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    285's will rub the UCA's on stock wheels at close to full turn. Will also need to remove/trim the front mud flaps and the front portion of the inner fender well.
  3. Mar 28, 2011 at 10:02 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    even at 2.5", you'd have to trim. and you'd need spacers to keep from rubbing the UCAs w/ 285s unless you have aftermarket rims.
  4. Mar 28, 2011 at 10:09 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    X2 with the above comments!
  5. Mar 28, 2011 at 12:05 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    x3, need more lift and spacers. Then you can trim away...
  6. Mar 28, 2011 at 12:10 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
  7. Mar 29, 2011 at 12:47 PM
    xGManx
    Garrett
    South
    06 DC LB
    aight, mudflaps are already removed, so trimming and spacers, how big of a spacer and what brands are good?
  8. Mar 29, 2011 at 12:55 PM
    jhodge83
    SC
    17 XLT Sport
    spidertrax 1.25"
  9. Mar 31, 2011 at 3:53 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Hello,
    So .... if you are going to install new wheels with the 285's, what wheels should you order to give you the equivalent to the 1.25" spidertrax?
    Cheers.
  10. Mar 31, 2011 at 4:26 PM
    jhodge83
    SC
    17 XLT Sport
    ~4.5" BS wheels
  11. Mar 31, 2011 at 6:49 PM
    Taco-NB
    New Brunswick
    Then there would only be rubbing that could be taken care of with trimming?
  12. Mar 31, 2011 at 6:50 PM
    KPT
    09 Prerunner
    With 3" of lift there would be minor rubbing
