Will 2nd Gen wheels fit on my 3rd gen tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mah185, Mar 27, 2023.
  1. Mar 28, 2023 at 8:51 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    This is 12° SAI at factory ride height. It doesn't account for camber or tire deflection.
    Tire deformation from camber or load would increase the scrub radius, so I didn't include it. For reference, tire deformation from 0.5° camber increases scrub radius by about 0.2 mm. 10 mm shorter tire radius from applied load increases scrub radius a further 2.1 mm. Radius reduction from loading decreases slightly while rolling and when the tire pressure increases from the tires heating up. I don't have the tire data to give a very realistic tire radius deformation value though, 10 mm is a complete guess.
    Jeff
    splitbolt[QUOTED] likes this.
  2. Apr 2, 2023 at 3:36 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Fantastic info, thanks for that. Puts my mind at ease about stepping up from 265/65R17 to 255/75R17 on +30 7.5” Sport rims and not going to a resultant negative scrub, which I was concerned about and was hesitant to choose that tire size as a result.
  3. May 18, 2023 at 8:26 AM
    Riegs
    Riegs Active Member
    Adam
    Dubuque, IA
    2017 DCSB TRD Sport SSM
    Not to thread jack, but would a 6 lug from a 2009 fit my 2017 TRD Sport? I don't care how it rides because I'm only swapping out my aftermarket Methods from the truck because my truck was totalled and insurance isn't giving me hardly anything back on the aftermarket parts. They said I could take the wheels off but had to replace them with something. I found some 2009 wheels with 265/75/16 tires on them. Will they fit just fine? Or do I need spacers at all?
  4. Sep 12, 2023 at 8:35 PM
    Van_island
    Van_island Well-Known Member
    Isaac
    2019 taco
    i have a 19 sport . found some 5 spoke 17'' 7.5 6 lug from a 4runner limited 04 30ET will they fit with 265 65 r17 tires???
