Will 2nd Gens gain more value?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lambada, May 19, 2023.
  1. May 21, 2023 at 1:20 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Interesting, no plans to trade or sell, but my bought new thelast day of 2009, is my 2010 DCLB Prerunner with 92,000 miles, other than break in, always hasMobil 1 in the engine, Automatic Transmission, Rear Axle, and I have been corrosion proofing the frame with Corr Ban 22 that we corrosion proof aircraft structures with may last longer than me…
    AngryChair1983 and davidstacoma like this.
  2. May 21, 2023 at 1:35 AM
    Lambada
    Lambada [OP] Active Member
    Simba
    Arizona
    2013 T|X Pro DCSB
    what about this 2013 TX Pro for 25k has 114k miles
  3. May 21, 2023 at 2:52 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    Just bought my TX Pro with 78k miles for 23k
    TacoSR523 likes this.
  4. May 21, 2023 at 7:10 AM
    HWI
    HWI Well-Known Member
    North Florida
    2015 Tacoma TRD Off Road
    2nd gen resale is already pretty dang high. In particular, the 4WD TRD models and especially the 2.5 gen 4WD TRD models have pretty high resale. At least this is the case in the area I live.
    birry likes this.
  5. May 21, 2023 at 7:14 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I have had a few people approach me and ask if I would be interested to sell. My response is always “ that would be a terrible financial move on my part”
    RedDemolisher and TacoSR523 like this.
  6. May 21, 2023 at 9:44 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Older Turbo in the Toyota etc sure. New Turbos No Thanks. The reliability of them is questionable. Sure, maybe once they get the issues worked out if them, and hopegilky you dont hzve a failure after the warranty has run out.. $300 won't buy you a turbo replacement on a new engine.
    Plus my comment had nothing to do with olderToyota Turbo equipped engines. It was obviously meant towards the new ones. The unproven ones!!!
    I dont feel like being the unlucky one to get one with issues. Even down the road.
    Shall l even mention that in some places in the world replacing a Turbo costs a small fortune!!
    Yes. There are other parts of the world outside of the U.S. Believe it or not. $300 wouldn't even cover the shipping and duty!!!!
    GSPdog7 likes this.
  7. May 21, 2023 at 9:49 AM
    shabbs
    shabbs Well-Known Member
    Mark
    Toronto, Canada
    2014 Tacoma 4x4 V6 DCLB TRD Sport
    Skid plate - added 2014/10/23, Bed extender - added 2014/10/25, Tonneau Cover - added 2014/10/31, OEM Bed Mat - added 2014/11/12, AM/FM/CB AntennaX - added 2014/11/16, Smittybilt 27046B Beaver Step for 2" Hitch - added 2015/01/22, Trimax SXT3 Premium 5/8" Key Receiver Lock - added 2015/01/22, 2 x Grip 30' x 4" Heavy Duty Tow Straps - added 2015/01/23
    Indeed. You'd have to shell out big time for another and be faced with wait times... I'll keep on enjoying the "no truck payments" life thankyouverymuch.
    birry and taco912 like this.
  8. May 21, 2023 at 10:14 AM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    When people offer to buy my truck, I tell them $40k. I don't want to sell, but that would clear up all my debts, and leave me with enough for an older Rav4 and a down payment for a house.
  9. May 21, 2023 at 10:25 AM
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
    It doesn't matter to me. My '06 170K mile OR is my last truck. I just moved it from daily driver work truck to recreation, camping, kayak, yard hauler. I, fingers crossed, can put another 100k on it over the next 15 years and both of us will be done. Whatever maintenance it will need, it will be way cheeper than buying an any newer Tacoma while continuing to fulfill its destiny. And I will have had 25+ years of zero truck payment.
  10. May 21, 2023 at 10:31 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Not to mention the lack of a four door Access Cab.
    Gonna stick with mine for the foreseeable future if not longer :D
  11. May 21, 2023 at 10:56 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    My truck gets more valuable every day I own it.
  12. May 21, 2023 at 11:55 AM
    HWI
    North Florida
    An OEM replacement Garrett turbo for my 06 Duramax was over $1200 just for the turbo. Would have probably been a solid $1500 in labor if I hadn't done it myself. The only turbo you're getting for $300 is going to be straight from China and the impeller and/or bearing is going to explode in a few thousand miles sending metal chunks into your engine. When it comes to quality turbos they are expensive and I do agree that a quality turbo is reliable, but the fact of the matter is that it is an additional failure point and you have to include the oil lines, coolant lines (if the particular application has them for the turbo), intercooler, BOV (if not variable geometry), and hot and cold side tubing. Bottom line imo, naturally aspirated engines have less failure points than comparable turbo charged engines.
    kidthatsirish and AngryChair1983 like this.
  13. May 21, 2023 at 12:25 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    lol its fun reading threads like these. where people argue what is better. n/a or turbo.
    i imagine back in the day, people were arguing the same thing, where a 1970 Cadillac had a v8 7.0 liter engine and the owner would talk smack about the upcoming civic. how it would not have enough power to get up the driveway, and not be reliable.
    im sure that the new 4 cylinder turbos will be great. its made by Toyota. a huge company who is famous for having reliable cars. im sure they did lots of testing and research.
    as far as the value of 2nd gen trucks, the prices will probably slowly go down, since we are driving them and putting miles on our trucks. but there is a limit. i dont think the 2nd gen will ever drop below $10k-$12k.
  14. May 21, 2023 at 12:50 PM
    spitdog
    Toyota made a 4 cyl turbo in 86 and 87 I think. They were bulletproof and reliable. I had mine over 15 yrs. No problems
  15. May 21, 2023 at 4:42 PM
    #35
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Ford set it all in motion when they went to EcoBoost. But the plus side of turbos being more common means supplier competition will be fierce to make a reliable model and to offer it at a good price.
  16. May 22, 2023 at 3:41 AM
    #36
    shonuff
    shonuff Well-Known Member
    07 DCab 4x4
    About 2 months ago i totaled my 07 4x4 4.0 with just shy of 170k. It was overall in "good condition". I was really hoping their insurance insurance give me as close to 10k as possible. Well to my suprise i got check for 19,550. And about 1 week ago i got a call from a sales manager at one of the Toyota dealerships asking if id be interested in trading my tacoma in or outright selling it to them. Said the 2nd gens, especially preface lift ones are gaining value like crazy right now. Like how the first gen Tundras are skyrocketing in value rightnow. So yah i know for sure they are gaining value right now
    kidthatsirish and OffroadToy like this.
  17. May 22, 2023 at 8:40 AM
    #37
    SomeGuy_GRM
    My dad likes my pre-facelift Tacoma because it's "one of the last proper looking trucks ever built.“
    RockfordTaco2006 likes this.
  18. Jun 8, 2023 at 12:26 PM
    #38
    Lambada
    Simba
    Arizona
    2013 T|X Pro DCSB
    damn bro got pics?
  19. Jun 9, 2023 at 7:19 PM
    #39
    Shotgun Clay
    Shotgun Clay Well-Known Member
    I got a 2013 last week with 100K on the clock, loads of preventive service records, one owner (who was obviously an older dude since the tires were Michelin LTX M/S2). Did I pay a premium? Perhaps, but I collect guns and sometimes the deal is being able to get the item at all (like a shotgun that had less than 30 made total). I drove into see it, in a 2006 Frontier suffering from multiple organ failure and signed on the dotted line. (The dealer was a small family owned outfit I’d been treated well at before). Retired I drive wel under 5K a year and wanted a “forever” truck. Could not be happier.
    MSgt O, Normshark and shabbs like this.
  20. Jun 9, 2023 at 10:40 PM
    #40
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    The part about getting the item is huge. Call it FOMO or whatever but if you find what you want and it's not easy to find, paying the money is almost always the best option in my book especially for a need item like transportation..
    Says the guy who drove 5-6 hours 2 states over to buy an old bicycle, of course....
    MSgt O and RedDemolisher like this.
