Will 33-12.5/17LT fit on an 08?
Discussion in 'Wheels & Tires' started by Joeymgd78, Jan 3, 2012.
  1. Jan 3, 2012 at 9:07 AM
    Joeymgd78
    Joeymgd78 [OP] Well-Known Member
    Joey
    at the moment Afghanistan
    2008 Tacoma SR5 TRD Offroad 4.0 V6 Double Cab
    will 33x12.50R-17LT fit on a 08 tacoma not lifted
  2. Jan 3, 2012 at 9:14 AM
    Joeymgd78
    Joey
    if not what is the largest size that will fit
  3. Jan 3, 2012 at 9:21 AM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    I would prefer a lift if you're gonna be running 33's.
  4. Jan 3, 2012 at 9:22 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yes, it will fit but you will be doing a lot of cutting
  5. Jan 3, 2012 at 9:30 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I run 255/75R17 on my truck with a 3 inch lift and have no rubbing/trimming, and thats a 32" tire. I heard you can run my size with no lift, but a 33 you'd be cutting and trimming a good bit.
  6. Jan 3, 2012 at 10:01 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    The quick and easy awnser is NO.
  7. Jan 3, 2012 at 10:20 AM
    Joeymgd78
    Joey
    will 265x70r17 look too small with a 2.5 inch lift
  8. Jan 3, 2012 at 10:32 AM
    plee33
    Peter
    Sacramento, CA.
    I personally think 265/70/17 will look too small with a 2.5" lift. 265/70/17 mud terrains will look good on stock height, but if you're going with a 2.5" lift then 33's will be your best option.
  9. Jan 3, 2012 at 10:37 AM
    Joeymgd78
    Joey
    ok im gonna go 33x12.50r17 then thanks for your help
  10. Jan 3, 2012 at 10:42 AM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    I have 285/75s on mine with a 3", little bit of rubbage but no big deal!
  11. Jan 3, 2012 at 10:44 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Without a lift you will probably not make it out of the parking lot. 12.5 is pretty wide and you'll hit fenders as soon as you turn the wheel. I am lifted and run 9.5" width rims with 33" mud terrains and I had to trim a couple inches off the fenders.
  12. Jan 3, 2012 at 10:47 AM
    plee33
    Peter
    Sacramento, CA.
    285/70/17 MAX.
  13. Jan 3, 2012 at 10:47 AM
    Joeymgd78
    Joey
    lol damn it this is a pain
  14. Jan 3, 2012 at 10:54 AM
    Joeymgd78
    Joey
    im going to put a 2.5 lift before the tires but the 305x70r17 is too wide huh? this sucks
  15. Jan 3, 2012 at 10:57 AM
    Joeymgd78
    Joey
    ok so im going 285x70r17 with a 2.5inch lift that should be good right guys
  16. Jan 3, 2012 at 11:08 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    you'll need wheel spacers if you are running the stock rims.
  17. Jan 3, 2012 at 11:09 AM
    Joeymgd78
    Joey
    im getting the dc2 rims with 4.5 back spacing
  18. Jan 3, 2012 at 11:19 AM
    TexasTacoma37
    Those will work, but you'll still need to trim some plastic and possibly chop your cab mounts.
  19. Jan 3, 2012 at 11:30 AM
    plee33
    Peter
    Sacramento, CA.
    Cab mount should be fine, but flaps have to go.
  20. Jan 3, 2012 at 11:34 AM
    TexasTacoma37
    Some have to chop their cab mounts, some don't. It has to do with how aggressive the sidewall of the tire is.
