Will 33" tires fit with a 3" lift on my 07 tacoma
Discussion in 'Wheels & Tires' started by Vos23, May 6, 2015.
  1. May 6, 2015 at 6:28 PM
    Vos23
    Vos23 [OP] Member
    07 TRD Sport
    3" Lift, Halo LED, K&N Intake.. On and on
    I just ordered a lift and will be arriving shortly, i need tires, my old stock size in pretty worn. I would like to squeeze 33" under it but i do not wanna hack my inner fenders.. Any one know if they will fit?
  2. May 7, 2015 at 12:14 AM
    huli467
    huli467 Turning Octopus
    Honolulu
    2015 TRD Sport 4x4
    The world is big...and I want to have a good look at it...before it gets dark - John Muir
    They fit on mine. I did take a bit off of the rear lower corner of the flare and obviously front mud flaps have to go. It fits pretty decently but I haven't fully cycled the suspension in an off road environment yet.
  3. May 7, 2015 at 1:00 AM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    I have a '14 with 3" and 33-12.5 tires, took a bit of trimming not to rub.
  4. May 7, 2015 at 1:02 AM
    Texas T
    TX
    '14 T Force
    Had to cut into the cab mount as well.
  5. May 7, 2015 at 1:04 AM
    Texas T
    TX
    '14 T Force
    Nothing more satisfying than cutting a $36k truck the fuck up.
    medic2230 and Anelson24 like this.
  6. May 7, 2015 at 1:10 AM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I have an 07 with a 2.5" leveling Kit. I run 285/70r17 tires on it and they rub a bit but not bad. I recommend running 265s and you will be clear! No trimming most likely.
  7. May 7, 2015 at 1:14 AM
    Texas T
    TX
    '14 T Force
    But 265 is like stock size.
  8. May 7, 2015 at 1:16 AM
    Texas T
    TX
    '14 T Force
    I have 295 55 20 on 3" lift. Minimal trim and cab mount chop, fits perfect.
  9. May 7, 2015 at 6:19 PM
    Vos23
    Vos23 [OP] Member
    07 TRD Sport
    The mud flaps have been gone for a while, within the forst month after i bought it it got ripped off by a stump hauling out firewood. Im hoping i can do just about no cutting, but we will see. Id really like to get that extra 1" lift from the tires. Anybody tried the BFGoodrich KO2's??
  10. Jun 24, 2015 at 9:40 PM
    xxsoccafreak09xx
    xxsoccafreak09xx Well-Known Member
    Louisiana
    2009 Prerunner Lifted
    17" dick cepek rims with 33" nitto mudgrapplers tires, 3" lift, Fishing rod rack.
    What kind of rims do you have? any offset?
  11. Jun 24, 2015 at 9:48 PM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    You will more than likely rub with 285s. I did on my 07 with a 3" lift and most others do as well. I trimmed a bit of the front bumper and a tiny bit off my fender flare where the mudflap was. It isn't noticeable at all unless you get in close and really look...haven't rubbed since. 285s look so good on our trucks, IMO the little bit of trimming is totally worth it.
  12. Jun 24, 2015 at 9:51 PM
    xxsoccafreak09xx
    Louisiana
    Do you think 295/55/20 can be ran on stock rims without major rubbing on a 3" lift?
  13. Jun 24, 2015 at 10:00 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Honestly man, it seems to depend on a few things: the truck, the tire, the alignment, and some magic haha. I have a 3" OME lift on my '06 with 285/70/R17 KO's and I don't rub at all aside from the mud flaps (but those pieces are gone :D). I'd say you should be fine with KO2's and I've heard pretty solid reviews on them. Also depends on the alignment, I believe camber moves your wheel forward or backwards, and therefor depending on your camber degree, you might rub the front or rear fender, or neither. Some guys have to trim, but others (like myself) didn't have to trim anything at all. All I did to fit them was remove the mud flaps and I have 1/4" wheel spacers so I don't rub on the UCA's.
  14. Jun 25, 2015 at 3:01 AM
    Texas T
    TX
    '14 T Force
    I have 20x10 havok wheels with 4.5" backspace.
  15. Jun 25, 2015 at 4:20 AM
    jwfrazie
    jwfrazie Member
    2007 Toyota Tacoma Sport
    Do you have any pictures of your truck. I am looking to do the same to mine and want to see what it looks like before I invest the money.
  16. Jun 25, 2015 at 4:26 AM
    7six2Fan
    7six2Fan Well-Known Member
    Dave
    Maine
    '13 TRD Sport DC LB
    Stock rims aren't 20's...
  17. Jun 25, 2015 at 6:16 AM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    What he said...
  18. Jun 25, 2015 at 7:27 AM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Yup, check out the build thread in my signature below "Millertime's build"
  19. Jun 25, 2015 at 7:31 AM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    A 255x85r16 in a KM2, Toyo MTR & Cooper ST are 33.2 and will stuff on a 3" with no trimming due to how thin they are.
    I'm jumping to a 285x75r17 and will need a CMC, pinch weld beating and some plastic down low cut.
  20. Jul 14, 2015 at 10:06 AM
    jwfrazie
    jwfrazie Member
    millertime89:
    I have changed the headlights, foglights, and taillights with new Black TRD Sport decals on the bed.
    I am taking my truck in this Friday to have a Rough Country 3 inch suspension lift, 20 inch Fuel Hostage Wheels with 33x12.50x20 Fuel M/T Gripper tires.
    I will post pictures as soon as it is complete.
