Will 33s fit on a 3rd gen stock suspension?
Discussion in 'Wheels & Tires' started by Jlsperanzella, Oct 29, 2017.
  1. Nov 5, 2017 at 6:19 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    It varies but not so well. 13 mpg average in town. On highway I've seen as low as 8.6. These 3rd gens weren't made to add a ton of weight and still get good mpg. @erok81 can attest to it
    SandyTaco4x4 and Tacomamike mike like this.
  2. Aug 29, 2019 at 2:32 PM
    MegaHurts777
    MegaHurts777 Well-Known Member
    Jacob
    ID
    2019 Tacoma TRD Off-Road (MT)
    What brand were you using when running the 255/85/16 on your stock wheels? I'm also looking at larger tires in the future but want to plan accordingly and avoid chopping if I can help it.
    Thanks!
  3. Aug 29, 2019 at 5:13 PM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Running cooper ST maxx at the time with TRD FJ trial wheel. You wheel specs will determine what you need done to avoid rubbing and what type of things doing with your truck.
    Good luck
  4. Aug 30, 2019 at 5:32 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    I just upgraded to 33's and was already thinking about regearing lol
    90yota[QUOTED] likes this.
  5. Aug 25, 2020 at 1:05 PM
    VeteranTacoma
    VeteranTacoma Active Member
    Jon
    2019 Tacoma TRD Pro Black
    Red 18 Piece Inserts, Red Tacoma Letter on Tailgate, TRD Seat Belt Pads, LED Lighting Interior and Tail Lights, American Flag Emblems, Console and Glove Box Organizer, Tuff Skinz Interior Letters and Accents, Door Sill Protectors and Red Lettering, TRD Fuel Cap Cover, Goodyear Rain Guards, Bug Deflector.
    I am looking at Cooper Discoverer STT Pro All-Season LT305/70R16 124/121Q Tire. How much lift will I need on a 2019 TRD Pro?
  6. Aug 25, 2020 at 1:07 PM
    CRASHMAN50
    CRASHMAN50 Well-Known Member
    AA-ron
    Arkansas
    '24 Tundra Limited TRD Lift
    *big sigh*
  7. Oct 18, 2020 at 7:57 AM
    Vst
    Vst IG:@vehiclesupportedtravel
    Scott
    Kodak, TN
    18’ Access cab TRD OFRD 4x4
    Decided to kinda revive this thread before starting a new one but I have a question. I’m looking to add larger tires and rock sliders I can’t afford to do both and the suspension I want at the same time. What’s really need to fit 285’s on a 3rd gen trd OR? Is it just a matter of a cmc and some front plastic trimming? I plan to use the stock OR wheels for now and add a spacer if needed. I know I can run 255’s with out much of an issue but they don’t make the kO2’s or wild peaks in that size for a 16” wheel. Thanks for any help and info!
    jcmotr likes this.
  8. Oct 18, 2020 at 8:15 AM
    jcmotr
    jcmotr Well-Known Member
    I first added 2” lift, then added BFG KO2 285/75R16 and it rubbed a ton. Then I did a CMC + pinch weld and it reduced the rubbing, but being on stock OR wheels I had to add wheels spacers for no rub. Now it’s fine and doesn’t rub unless full lock and compression.
  9. Apr 25, 2021 at 8:22 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    Is this legit? I want to fit 33 on this exact wheel spec and I don't want a lift. Cmc and pinch weld but no lift sounds great if it works.
