Will 33s on stock rims fit without lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nc12vpower, Aug 17, 2015.
  1. Aug 30, 2015 at 2:06 PM
    Nc12vpower
    Nc12vpower [OP] Member
    Gray 2011 tacoma TRD Sport
    5% tint on all the windows and 35% on the front windshield
    What about 16x8 with like a 31x10.50?? On stock suspension. Will that still rub?
  2. Aug 30, 2015 at 2:13 PM
    Doak110
    Doak110 Well-Known Member
    Doug
    Howell , NJ
    2015 white Tacoma trd
    6in bds lift with Fox 2.5 factory coil overs and shocks Fuel rims 20x9 Toyo open country MT 33x12.50 Flow master cat back K&n cold air intake Bp fab grill 20in lightbar 2 3x3 Kc cubes 1.25in spider track wheel spacers HIDs headlights and fogs Red line hood struts Weather Tec mats
    I had 33x12.5 and I rubbed pretty bad and that was with a 3in lift it would hit the fender flare the uca and the frame at full lock
  3. Aug 31, 2015 at 5:32 AM
    Nc12vpower
    Yeah but the 8inch wide rim is wider than the stock rims.
  4. Aug 31, 2015 at 5:52 AM
    Pigpen
    Dan
    Northwest Montana
    The width of a 255 works in our favor, as long as you don't have offset rims or wheel spacers. You could make this work by doing some trimming behind the mudflaps. A heat gun and some massaging might even work. Many people ask about 33s on stock suspension, but I've never read about anyone actually trying it.
    I'm pretty sure that my 5100s at the 1.75 setting have a longer compressed length than stock struts. If I'm right, this helps my setup work. I haven't done any trimming and I have mudflaps on (not stock flaps)
  5. Aug 31, 2015 at 6:00 AM
    Nc12vpower
    What does your setup look like
  6. Aug 31, 2015 at 8:22 AM
    Nc12vpower
    I want to keep my mud flaps from rocks being thrown. Like a stated before.
  7. Aug 31, 2015 at 10:59 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    For 255s, no and no. Increasing backspace from stock with spacers or different wheels moves things outward and increases the pivot arc of the tire. That makes them rub front and rear at full lock even more. Lift doesnt change that geometry.
  8. Sep 22, 2019 at 5:52 AM
    djgynee
    djgynee Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    THATS a SPICY PIZZA
    sorry had too make reference to “ that’s a spicy meatball”
    yota243[QUOTED] likes this.
  9. Mar 5, 2024 at 12:05 AM
    natergator
    natergator New Member
    idk if youll ever see this as it is from a while back but is this with no lift?
  10. Mar 5, 2024 at 3:09 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Nothing in the rear, Bilstein 5100 set at 1.75" up front, but there are people in the 255/85 thread that are running stock iirc
  11. Mar 5, 2024 at 4:31 PM
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    I have 285/70-17 and the tires would rub in reverse or forward on the aft mud flap and forward mud flap. Got rid of the forward one and cut out a section of the aft one and had no more rubbing. My rims are the 4Runner Trail Rims and my tire is about 1/2 in from the upper control arm. Offset/Tire Center line plays a huge role in the rubbing department. All in all I wish the I went with pizza cutters just to save the weight on rotational mass.
