Will 33x11.50's fit
Discussion in 'Suspension' started by Wild_Country, Nov 13, 2009.
  1. Nov 13, 2009 at 9:12 PM
    Wild_Country
    Wild_Country [OP] New Member
    Oregon
    Tacoma SR5 V6
    Rancho quicklift struts up front, add-a-leafs in the rear, k&n cold air intake
    I'm needin new tires and have the rancho quicklift struts with add-a-leafs and am wonderin if I can fit the 33's w/o rubbin on the inside of the wheel wells up front.
  2. Nov 14, 2009 at 3:01 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    well if u have at least a 2.5" in the front u'll still need to remove the front mudflaps and trim as well to fit that size.
  3. Nov 14, 2009 at 12:55 PM
    Wild_Country
    Oregon
    Tacoma SR5 V6
    Sweet thanks, I've taken the mudflaps off already, actually lost one last huntin season so I just took the other one off. With the tires cranked either right or left I still have about 1 1/4 at the closest point.
  4. Nov 14, 2009 at 12:58 PM
    The_Hodge
    SC
    one thing i forgot to mention....are you going to run stock rims w/ them? if so u'll need either spidertrax spacers or new UCA's....if new rims w/ 4.5" backspacing u can disregard
  5. Nov 14, 2009 at 12:59 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    11.5 is a pretty wide tire
    unless you have aftermarket wheels theres a good chance youre going to rub on the upper control arm
  6. Nov 14, 2009 at 1:16 PM
    The_Hodge
    SC
    ^^ i didnt notice the 00 year, so i could be wrong in that. either way i'm sure that the stockers will fit the 285's, but definately suspension rubbage
  7. Nov 14, 2009 at 1:20 PM
    JimBeam
    JB
    2015 Tundra
    im super close to my UCAs and the ivan wheels stick out about .5" more than stock wheels and ive got 285/75/16s
    id bet on stock wheels = rubbing with 11.5 wide tires
  8. Nov 14, 2009 at 1:30 PM
    The_Hodge
    SC
    285's are right at 11.25...so definate rubbage on a true 11.5 and stockers
  9. Nov 14, 2009 at 1:31 PM
    JimBeam
    JB
    2015 Tundra
    ish yeah...id rub if i was on stock wheels
  10. Nov 14, 2009 at 1:32 PM
    The_Hodge
    SC
    ^^ i edited as u posted...lol
  11. Nov 14, 2009 at 1:43 PM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    i got about 2.5" with 285s and im runnin mt classic IIs....i only rubbed on the pinch weld
  12. Nov 14, 2009 at 1:44 PM
    JimBeam
    JB
    2015 Tundra
    oh yeah forgot about the pinch weld
    thatll need to be hammered flat too
