Will 33x12.5 fit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Donkey40, Jul 1, 2018.
  1. Jul 1, 2018 at 2:08 PM
    Donkey40
    Donkey40 [OP] Active Member
    05 TRD sport AC
    Ordered a 3 inch front leveling kit for my 05 access cab. Also ordered 33x12.5 and I’m keeping the stock trd sport wheels. Will it fit? And if not will a spacer help?
  2. Jul 1, 2018 at 2:15 PM
    Donkey40
    05 TRD sport AC
    Some trimming is okay, I’m not wanting to do cab mount chop
  3. Jul 1, 2018 at 2:45 PM
    Brandon2330
    Brandon2330 Well-Known Member
    Brandon
    Houston, TX
    2016 Tacoma TRD Off-Road 4x4
    OME Lift & Leer 100XL top
    You might rub a little at full turn, but you should be fine as long as all mud flaps have been removed. It’ll definitely be close.
  4. Jul 1, 2018 at 2:46 PM
    Donkey40
    05 TRD sport AC
    I’m okay with it rubbing a little I just don’t want it to be anything major where I have to cut and weld
  5. Jul 1, 2018 at 3:05 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    You will need spacers on stock wheels. That’s also a wide tire for a 7” Wheel. Although, I know some do it.
    Spacers and a cab mount chop, at least, will be needed I’d imagine.
    BassAckwards likes this.
  6. Jul 1, 2018 at 3:36 PM
    Donkey40
    05 TRD sport AC
    I’ve seen 35 mud grapps on 17x7s. I read that if you keep the psi from getting extremely low it’ll be okay.
  7. Jul 1, 2018 at 3:36 PM
    Donkey40
    05 TRD sport AC
    Can you do it without welding a plate back on?
  8. Jul 1, 2018 at 3:36 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Like I said. I’ve seen it done.
  9. Jul 1, 2018 at 3:38 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I just looked. Sport wheels are actually 7.5”
  10. Jul 1, 2018 at 3:40 PM
    Donkey40
    05 TRD sport AC
    As long as the tire shop will mount them that’s all I care about. I like the look of big tires on stocks
  11. Jul 1, 2018 at 3:50 PM
    Donkey40
    05 TRD sport AC
    Yeah it does make it look great but I don’t have too much welding experience. Do you think the 3” will make the truck sit higher in the front or will it level it out
  12. Jul 1, 2018 at 3:56 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    That would cause uneven wear resulting in the middle of the tire wearing out faster.
  13. Jul 1, 2018 at 4:00 PM
    Donkey40
    05 TRD sport AC
    Having too much air?
  14. Jul 1, 2018 at 4:02 PM
    Donkey40
    05 TRD sport AC
    I’ll check some places out when I get everything out on maybe something will come up bc if it’s going to rub extremely bad I’m gonna need it done soon. Don’t want to rub my tires down too quick
  15. Jul 1, 2018 at 4:07 PM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I would think even running low air pressure having a 12.5" wide tire on a 7" rim is going to cause uneven wear.
  16. Jul 1, 2018 at 4:07 PM
    Donkey40
    05 TRD sport AC
    Is there anything to do bout that
  17. Jul 1, 2018 at 4:08 PM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Wider rim? Minimum 10" wide?
  18. Jul 1, 2018 at 4:27 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Why don't you just go with 255/80/17 and no CMC.
  19. Jul 1, 2018 at 4:30 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    You do not need to weld a plate back on to the CMC. It’s purely aesthetic.
  20. Jul 2, 2018 at 2:17 PM
    Donkey40
    05 TRD sport AC
    I cancelled order for the 33x12.5s. Went with 285/70r17 trail grapplers. Hopefully that’ll work better
