will 35'' tires fit stock wheels?
Discussion in 'Wheels & Tires' started by JK4, Aug 9, 2009.
  1. Aug 9, 2009 at 10:15 AM
    JK4
    JK4 [OP] Member
    09 PreRunner Double Cab
    im planning on getting a 6 inch lift with 35 inch tires but i want to keep my stock wheels till i have enough money to buy some better ones so i was wondering if these 315/75/16 tires would fit the stock wheels
    it looks like they will diameter wise but i dont know about width???
    http://4wheelonline.com/ProCompAllTerrainTires.349.122529
    so the quesion is.. will stock wheels work with these big tires?
  2. Aug 9, 2009 at 10:17 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'm not positive but I think you will have to get wheel spacers and do some good trimming.:cool:
  3. Aug 9, 2009 at 10:31 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    The rim width range for those tires is 8.0"-10.0" so if you are going by the manufacture specifications, no they will not safely fit your factory wheels.
  4. Aug 9, 2009 at 12:30 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Nope... You should get atleast 8" wide rim for that size tire.
    The stock wheels are too narrow for a nearly 12.50" wide tire. The amount of air pressure you'd need to ensure the tires are flat on the road would be toooooo low and not safe especially when going around corners. The sidewall would bend/roll and could possibly come off the bead.
    If you're on a budget, you should be able to find 16x8 black steal rockcrawler wheels for under $100 each.
  5. Aug 9, 2009 at 12:30 PM
    Kenny650
    Kenny650 Well-Known Member
    Just save up.
  6. Sep 2, 2009 at 7:29 PM
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    will 13.5" tires fit on an 8" rim?
