Will 35s be an issue on Oahu?
Discussion in 'Hawaii' started by rick.mistic0312, Sep 4, 2018.
  1. Sep 4, 2018 at 11:37 PM
    rick.mistic0312
    rick.mistic0312 [OP] Member
    2009 Blue Tacoma crew cab
    6 inch Rough Country lift, 20x14 -76 XD8252, 35x12.5R20 Nitto Mud Grapplers
    What's going on? I'm moving to Oahu in December and my truck currently has a 6in lift w/35 inch mud grapplers. Is this going to be an issue there? I was told 33's are the biggest you can go in Hawaii. Any info you can give would be great. Thanks in advance!
  2. Sep 4, 2018 at 11:48 PM
    DEDAFLO670
    DEDAFLO670 Well-Known Member
    Manuel
    Waipio
    15 Trd sport
    As long as you could pass recon to be legal you are good.
    seoulja99 likes this.
  3. Sep 5, 2018 at 12:05 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
  4. Sep 5, 2018 at 12:24 AM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    The 35s won't be an issue, some people run larger tires. The tires have to be under the fenders, so the tread that touches the ground is covered when viewed from above. Also, the rear tires have to have mud flaps, covering the full width and half the height of the tire when viewed from the rear. You'll also need an alignment print out, with your numbers within spec.
    raycie, seoulja99 and bullaculla like this.
  5. Sep 5, 2018 at 1:02 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    My truck passed inspection with 37s.
    raycie and beertimecontinuum like this.
  6. Sep 9, 2018 at 2:20 AM
    rick.mistic0312
    What type of things will they look for one the recon? My offset is -76 so the tires stick out pretty par? What happens if they fail the truck or what kind of things will make the truck fail?
  7. Sep 9, 2018 at 2:44 AM
    DEDAFLO670
    Manuel
    Waipio
    15 Trd sport
  8. Sep 9, 2018 at 5:00 AM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
