Will 35's fit with 1" leveling kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB Voodoo, May 15, 2013.
  1. May 15, 2013 at 7:56 AM
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The subject says it all.
    2013 TRD Sport. I have four leafs in back, and a 1" leveling kit in front.
    Wondering if 35's will clear....
  2. May 15, 2013 at 7:58 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Not without cutting, pounding, and glass front and rear. I would highly suggest not to do this. 33's/ 285's will even require a cab mount chop, pounding the pinch weld back, and possibly even cutting/ clearancing your fenders.
  3. May 15, 2013 at 7:59 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Only if you leave the truck on jack stands.
  4. May 15, 2013 at 8:00 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    What if I put wheels on the stands????????
    Haha...
    So the biggest I can get away with is 265/70-17 or 255/75-17?
  5. May 15, 2013 at 8:01 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    That is what I would suggest.
  6. May 15, 2013 at 8:08 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
  7. May 15, 2013 at 8:11 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    :popcorn:
  8. May 15, 2013 at 8:12 AM
    Large
    Large Red
  9. May 15, 2013 at 8:17 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I kinda figured they wouldn't fit.
    I'll just get some 255/75-17 Trail Grapplers and be done with it.
    Thanks guys!!
  10. May 15, 2013 at 10:30 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    On top of no fitting your performance would drop off the cliff
  11. May 15, 2013 at 11:36 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    You're still going to need to trim the fenders and if you wheel you'll end up probably doing the cmc and pounding your pinch welds back...
  12. May 15, 2013 at 12:03 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You think?
    Right now I have 265/70-17 Cooper STT's with no lift, and they clear just fine.
    The only reason I was considering 255/75-17 is because that tire is only available in Load Range C in that size, but not in 265/70-17.
  13. May 15, 2013 at 12:08 PM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    Lots of debate in that thread on how to make 34's fit. I'm not going to bother.. I'll go 33 max I think.
  14. May 15, 2013 at 12:10 PM
    BulletToothTony
    Yep 255/75/17 is like 32.5 inches tall. You start flexing with those and you will rub on something.
  15. May 15, 2013 at 12:12 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    255/75/17 is 32" and essentially the same height as 265/70/17
  16. May 15, 2013 at 12:15 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    That's not true. I ran 285's for 2 yrs with only a spacer in the front . I also still kept the mud flaps on and did some hard wheeling . So no mount chop needed. :)
  17. May 15, 2013 at 12:24 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    255/75-17 is slightly taller, but definitely narrower.
    If I don't rub now without a lift, why would I rub with a slightly taller and narrower tire with a lift?
  18. May 15, 2013 at 12:38 PM
    BulletToothTony
    Some guys rub with 265/75/16's with no lift and flexing... I'm just trying to warn you that IF you start flexing with a 255/75/17 with no lift or even a 1 inch lift you will rub the fenders and *maybe* the cab mounts and pinch welds.
    I ran 285 duratracs in 2.25 inches of lift and and just had to trim my flares. When I went up to 33/12.5's I had to trim more fender and cut and beat my pinch welds. I rub slightly on my cab mounts and have plans to cut those in the future as well.
  19. May 15, 2013 at 12:41 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Are you talking about severe flexing under off road conditions?
  20. May 15, 2013 at 12:44 PM
    BulletToothTony
