Will 3rd Gen Tacoma shocks work on 1st Gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by graphiti, Jan 4, 2017.
  1. Jan 4, 2017 at 8:20 AM
    graphiti
    graphiti [OP] Expert Shade Tree Mechanic
    Bob
    Salt Lake City UT
    1999 TRD Tacoma Supercharged
    K&N cold air intake Flowmaster Muffler Flowmaster high flow catalytic converter load leveling rear suspension air bags
    My local classified ads have had several listings for 2017 Tacoma front and rear shocks for VERY cheap and I am in need of new shocks for my 1999 Tacoma, question is, will 2017 work on 1999 Tacoma. I'm a pretty experienced mechanic but I cannot find any definitive info on this topic.
  2. Jan 4, 2017 at 8:37 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    They're cheap for a reason... IMO, don't go there. Even if they did fit, (which I'm betting they won't, at least in the rear since the suspension designs are different), shocks that cheap and you might as well go to Auto Zone and buy their no name "brand" shocks for $10.
    Rockauto.com has shocks for your 99 starting at around $15 a piece. Cheap enough for you?
    Personally, just get some KYBs, or if you want the same quality (or better) that came on your TRD, get Bilsteins.
    http://www.4wheelparts.com/Lift-Kit...-Shocks.aspx?t_c=1&t_s=90&t_pt=3306&t_pl=9763
    http://www.rockauto.com/en/catalog/toyota,1999,tacoma,3.4l+v6,1357589,suspension,shock+absorber,7556
  3. Jan 4, 2017 at 9:37 AM
    graphiti
    Bob
    Salt Lake City UT
    The shocks are from a TRD Tacoma so they are Bilstein already.
  4. Jan 4, 2017 at 10:25 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Pretty sure the front struts have different upper mounts and the rear shocks are different lengths.
  5. Jan 4, 2017 at 10:43 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    No, they won't fit.
  6. Jan 4, 2017 at 10:48 AM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    I have to say I agree with the other members here. They definitely will not fit. It is not even worth your time to even attempt it. Your 1999 Tacoma is a 21 year old design, and a 2017 is a two or three year old design. They're not even close to having interchangeable parts. Look at the KYBs and the Ranchos when they go on sale.
    Good Luck,
    Paul
  7. Jan 4, 2017 at 10:52 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You may be able to use the rears if the lengths are close, and they are eye-to-eye. But not those fronts.
  8. Jan 4, 2017 at 10:56 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Fronts will not fit.
    Rear shocks are eye to stem, you need eye to eye. Rear will not fit either.
