Will 5100's accommodate a 3" REAR lift??
Discussion in '1st Gen. Tacomas (1995-2004)' started by brandnewcolony, Aug 13, 2011.
  1. Aug 13, 2011 at 12:50 PM
    brandnewcolony
    brandnewcolony [OP] Well-Known Member
    Fort Worth, Texas
    2017 Tacoma TRD Pro SW
    I just purchased the Eibach Coils form Toytec which I am planning on running with 5100's at 0 up front. My question is I have a 2" shackle currently and I know the 5100's in the rear will accommodate this,however, if its not sitting level or it's slightly higher in the front I will be adding a 1.5" AAL. Will the 5100's in the rear accommodate a 3.5 inch lift in the rear??? Or will I need the 5125's and if so which length. Thanks in advance for the help guys. I just want to get all the correct parts the first time around.
  2. Aug 13, 2011 at 1:33 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    No. You are better measuring for some 5125s because the 5100 will be nearly maxed out before droop.
  3. Aug 13, 2011 at 1:42 PM
    brandnewcolony
    Fort Worth, Texas
    Thanks Snowman! What if I go with the 5125's in the correct length I'm guessing 9" or 10" travel, and end up just running the 2" shackle and not adding the AAL. Will this Cause any problems?
  4. Aug 13, 2011 at 1:51 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    You should take the shocks you have off and measure the distance at full droop and when bottomed out on the bump stops. Then call downsouth motorsports or wheelers and tell them the lengths. They will be able to tell you which 5125s will work.
  5. Aug 13, 2011 at 1:55 PM
    brandnewcolony
    Fort Worth, Texas
    Any other way to get a ballpark estimate of what length 5125's to get without taking the shocks off???
  6. Aug 13, 2011 at 2:52 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    You dont really want to ballpark it because if they are an inch too long when fully compressed you will distroy the shock. They arent hard to take off anyway, just 2 bolts.
  7. Aug 13, 2011 at 4:45 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    10'' ones, but you will most likey need new bump stops as they compress all the way before the bump stops i think.
  8. Aug 13, 2011 at 5:03 PM
    brandnewcolony
    Fort Worth, Texas
    Snowman is that when I take the shock out and lower the truck down??
  9. Aug 13, 2011 at 6:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    to meassure you can just take your shocks out completely, you dont really need em to drive. then you have to lift one wheel as high as it will go then measure both the shock mounts. That will give you the longest and shortest distance to help determine what shock to get.
  10. Aug 13, 2011 at 6:54 PM
    brandnewcolony
    Fort Worth, Texas
    Lift the wheel with a jack from the axle? Do both sides?
  11. Aug 13, 2011 at 9:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Yes you need to lift from each side. After removing both rear shocks, lift one side until the front tire starts to come off the ground. With it up in the air, measure the distance between the shock mounts on both sides. Then do the same, lifting from the other side. You are looking to get 4 measurements in inches, 2 for each side. One will be a compressed number and one will be an extended number for each side.
    The idea is to get it fully flexed so there is no chance for the new shocks to overextend or over compress. Over extension and over compression will destroy a good shock.
  12. Aug 13, 2011 at 9:54 PM
    beanZnMyTaCo!
    beanZnMyTaCo! Well-Known Member
    beanZ!
    sj, CaLi
    DoPe!
    awesome pix for the situation! digi!
  13. Aug 13, 2011 at 11:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ^^what he said!
  14. Aug 14, 2011 at 1:40 AM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    I had 5100's in the back with my 3" fabtech lift and i blew one of my shocks out and it started leaking oil :(
  15. Aug 14, 2011 at 1:43 AM
    rcfreak201
    rcfreak201 Well-Known Member
    i just got the all pro 3" lift leaf pack and they said 9" shocks is what i need, 10 would be too long, i also found out that most shocks need a stem to eye conversion and that gives it about an inch of lift, so if the shocks you get require the converter piece you should get 8" shocks
  16. Aug 14, 2011 at 6:30 AM
    brandnewcolony
    Fort Worth, Texas
    ^^Thanks for the pics buddy. I bet having a forklift made things easier :)
    I talked to DSM and told them what I planned on running in the rear ( 2" shackle & 1.5" AAL) they said a 9" 5125 should do it. Does that mean I need to get a 10" for the passenger side due to the 1" difference like they come stock??? Thanks everyone for tour help!!!!!
  17. Aug 14, 2011 at 11:52 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    DSM shoulda told you that themselves...i know a guy who has a 3'' leaf pack and is running a 9'' one on drivers side and 10'' on pass...so maybe call em again?? :notsure:
  18. Aug 14, 2011 at 11:57 AM
    brandnewcolony
    Fort Worth, Texas
    I figured they would of told me that as well... I'll double check with them again tomorrow, that's when I was planning on purchasing them.
  19. Aug 14, 2011 at 9:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    To be fair, DSM is guessing too. Without actual measurements it is very difficult to know for sure. There are too many variables. You might be OK with their guess, on the other hand, one shock might be either a little short or a little too long. :notsure:
    Sounds to me like you want to be sure but are not willing to do what you can to help the cause. :)
  20. Aug 14, 2011 at 10:11 PM
    brandnewcolony
    Fort Worth, Texas
    Hahaha :) I am willing to follow your instructions to get the exact numbers but wouldn't I need the AAL installed prior to getting the measurements? As of now I only have the 2" shackle installed. Eibach coils are ordered and will be ordering the AAL tomorrow. The only thing holding me back is the 5125 measurements for the rear. I will be paring 5100's @ 0 with the Eibachs
