will 5100s and AAL void factory warrenty?
Discussion in 'Suspension' started by Lunercrab, Jan 11, 2010.
  1. Jan 11, 2010 at 7:02 PM
    Lunercrab
    Lunercrab [OP] Well-Known Member
    Beth
    Lehigh Valley area, PA
    2019 off road cement
    ok so on my 06 i had 5100's set at 2.5 front, with an AAL in the rear and i liked the height on the truck and the ride as well...now i just picked up my new 2010 tacoma sport and it bugs me how small my truck seems at factory height...so i wanna do the same set up in the new truck...question is since the truck is so new and still way within the 36k warrenty, will doing the lift void anything as far as the warrenty goes? i was gunna wait a year or two before doing the lift, but i miss the way my old truck looked :(
  2. Jan 12, 2010 at 9:49 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Someone can chime in but as long as it is dealer installed, then no...
  3. Jan 12, 2010 at 11:21 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Yes and no, obviously they won't replace aftermarket shocks if something goes wrong. But it shouldn't void anything, they have to prove that the new part is the cause of an issue if you have one.
    I would get the rear TSB done first then put the billies and AAL on.
  4. Jan 12, 2010 at 11:39 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    yes, your warranty is voided the minute you think about putting on aftermarket items, with that being said, I don't have a warranty and my truck is a perfect candidate for 5100's. :D
    please don't take a thing I've said to heart, I'm kidding
  5. Jan 12, 2010 at 11:44 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Simple answer, NO.
  6. Jan 12, 2010 at 11:44 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    http://en.wikipedia.org/wiki/Magnuson%E2%80%93Moss_Warranty_Act
    "Warrantors cannot require that only branded parts be used with the product in order to retain the warranty.[2] This is commonly referred to as the "tie-in sales" provisions[3], and is frequently mentioned in the context of third-party computer parts, such as memory and hard drives."
    They have to prove your aftermarket parts caused the damage you are trying to get fixed with the warranty.
  7. Jan 12, 2010 at 11:46 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
  8. Jan 12, 2010 at 11:46 AM
    08TRDOFFROAD
    Dan
  9. Jan 12, 2010 at 11:47 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
  10. Jan 12, 2010 at 11:51 AM
    Masada
    Taylor
    Laveen, AZ
    For clarity...
  11. Jan 12, 2010 at 5:38 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I was hoping...;)
    gotta check the ninja text
  12. Jan 12, 2010 at 5:41 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    they cant say that your shocks caused your motor to explode....
  13. Jan 12, 2010 at 5:44 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    they sure as hell try...we know this too..!! lol
  14. Jan 12, 2010 at 7:23 PM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
    I Agree
  15. Jan 12, 2010 at 7:25 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Huh? I like Karl Malone.
  16. Jan 12, 2010 at 9:29 PM
    Lunercrab
    Beth
    thanks guys...yeah a local meineke put on my last lift, hopefully i can get them to do it again (it only cost me alittle over 200 for them to install everything) i just miss the way my old truck looked...i thought i could wait to mod, but who am i kidding:D... i guess it all depends on the dealership...before i took delivery of the truck i was adament that i wanted the spring tsb done, but they told me i need to "replicate the harsh ride problem first" so what am i supposed to load up the truck and drive em around in it??? wondering if i should call toyota itself instead...but that being said if the front billies are set at 2.5 like i had in my old setup and if i do get the spring tsb done do i really need an AAL? i do want some rake for towing, i'm wondering if a 1.5 AAL would be enough...and also if the fronts set at 2.5 does that cause any long term damage? i didnt have a problem with my other truck, but i only had the lift on for a year....thanks again guys...
