Will 5100s help ride with truck loaded with passengers?
Discussion in 'Suspension' started by JTDTacoma, Aug 24, 2010.
  1. Aug 24, 2010 at 5:36 AM
    JTDTacoma
    JTDTacoma [OP] Well-Known Member
    08 4X4 Double Cab TRD Sport
    I have the TSB and stock TRD bilsteins. The truck rides perfect by myself or with a passenger. But I had 4 medium/small adults including myself in there (DC) and could feel that the ride quality was worse up front. I Imagine the springs were compressed more than I'm use to. I was thinking of getting 5100s set to .85 or 1.75 to level truck anyway but will that help a loaded-truck ride or does it have to do with the springs instead?
  2. Aug 24, 2010 at 11:14 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The 5100s have much better valving than your stock shocks. So you should see an improvement.
  3. Aug 24, 2010 at 11:15 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
  4. Aug 24, 2010 at 1:46 PM
    JTDTacoma
    Great thanks!
  5. Aug 24, 2010 at 2:24 PM
    MATOAKA
    MATOAKA Well-Known Member
    Takomus
    Norfolk, VA
    09 PreRunner
    trd cold air intake, trd cat back exhaust, austin tube running board, truxedo tonneau cover, toyota xm radio, vip security system, weather tech floor mats, weather tech side window deflectors, e-z down tailgate strut, redline tuning hood strut, shortie antenna, billies 5100s, u-haul tow receiver, patial debadge, sockmonkey VA trd sport bed sticker,
    After getting the Leaf Spring TSB I felt the stiffness on the ride compared to stock. I replaced the stock trd with billys 5100s with front set @ zero.
    The ride feels almost stock but better. It obsorbs road bumps well not bouncy. Truck rides solid now.
    Why zero? I don't mind the slight rake as I often have a load in the back so its level.
