will 6 lug 17 wheels fit on my truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by TunaTaco10, Dec 13, 2010.
  1. Dec 13, 2010 at 5:56 PM
    TunaTaco10
    TunaTaco10 [OP] New Member
    Arizona
    Lifted Xtra cab 4x4
    Have a 1995 tacoma w/ 2.5 lift running 285/75/16 on factory wheels. My buddy bought 20's and has available his stock alloys. Trying to find out if stock 6 lug 17 in wheels from a 2007 Tacoma will fit. Backspacing is my main concern for rubbing.
  2. Dec 13, 2010 at 6:09 PM
    x ynot
    x ynot Well-Known Member
    tony
    lucedale, ms
    06 xrunner and 99 prerunner
    step side k&n air filter tool box and running boards
    i dont see why not
  3. Dec 13, 2010 at 8:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    2nd gen wheels have less offset than stock, 1st gen alloys...by about 15 mm (~9/16"). With 285s, rubbing on the uca will be an issue with the 2nd gen wheels. 265s are likely OK, barely.
