Will 98-00 Fender Lights fit in 01-04 fenders?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SRQ TACO, Sep 21, 2011.
  1. Sep 21, 2011 at 5:21 PM
    SRQ TACO
    SRQ TACO [OP] Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    I have some 4wd fenders from a 03 that I wanna put on my truck but im not sure if my corner fender lights will fit. SO will they?
  2. Oct 5, 2011 at 10:14 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    oh ok thanks guys!
  3. Oct 5, 2011 at 10:39 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
  4. Oct 5, 2011 at 11:20 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Tad different Damon.
  5. Oct 5, 2011 at 11:22 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    the bumpers from the 01-04s are different than our 00's
  6. Oct 5, 2011 at 11:23 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    dur
  7. Oct 5, 2011 at 4:26 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    How much different?
  8. Oct 5, 2011 at 4:31 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    the 01-04's had a facelift from the 98-00's, with different lines and turn signal cutouts.
    01-04
    Edit:
    Unless you're talking about the corner parking lights?
    But still, theyre different. The reflector/entire unit is different between models
  9. Oct 5, 2011 at 4:45 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Having done the front end transplant on mine I can say that the fenders between the 4wd trucks are the same. It's probably the case with the 2wd as well...but you could measure to check and be exact.
  10. Oct 5, 2011 at 6:02 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    01-04 turn signals are shorter up top..your 98-00's won't fit correctly in 4wd fenders.
  11. Mar 8, 2012 at 11:47 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    TO bump I am talking about the corner lights in the fenders. The parking lights I guess you would call them. I need to know if my 00 parking lights will fit in 03 4wd fenders.
  12. Mar 8, 2012 at 3:34 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
