Will a 1.5" lift void my warranty - 2018 TRD offroad 4WD
Discussion in 'Suspension' started by Rjparnow, Nov 30, 2018.
  1. Nov 30, 2018 at 9:51 AM
    Rjparnow
    Rjparnow [OP] Active Member
    Robert
    Taco
    None yet
    Hello,
    I'm going to be doing a suspension upgrade in 3 phases with Fox 2.5 with remote res on my 2018 TRD Off-Road 4WD. I asked my dealer the cost on the suspension upgrade labor. He then told me that they would not do the 1" lift for me as it would void the warranty and create issues with my safety sensors. This seems like BS as I am only planning on lifting it 1", using the same suspension as the TRD pro. Anyone have any insight to this and if I should talk to another delear? i dont want to void my warranty as i only have 6k miles on the truck. Also feedback on my proposed phased upgrade approach would be awesome
    Phase 1 - suspension upgrade - leave at stock lift hight
    Fox Factory 2.5's with adjustable remote res
    Phase 2 - upgrade UCA's
    Phase 3 - Lift 1 - 1.5 inches install add a leaf springs
    Thanks in advance for the feedback!
  2. Nov 30, 2018 at 9:55 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Nov 30, 2018 at 10:02 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    I installed a lift on my truck a month after I purchased it new, never had issues, but I'd be wary if you have an issue that might be related to your mods, they'll be quick to point a finger at that. I never had to take my truck in for warranty except when my battery crapped out the first year, but since you have a third gen...;)
    Shortbus47XYY likes this.
  4. Nov 30, 2018 at 10:09 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    It’s about liability.
    A dealer can decline to service a modified vehicle and it has happened here before. Legally, the manufacturer has to prove the mods done have contributed to or caused a problem in order to deny your warranty.
    But, keyword is legally. Unless you take them to court, no is no. Even then, how much does your court process cost if you succeed..
    Modifying comes with inherent risks, so if you’re not comfortable with future unknowns and possibly creating a can of worms or causing additional wear and tear - don’t do it.
    Shortbus47XYY and Sub_Par like this.
  5. Nov 30, 2018 at 10:26 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    I understand your concern with it being a brand new truck. Bringing a modified truck into a stealership is almost always a problem. They're not OEM parts, plain and simple. If you're going to be heavily reliant on them to perform all of your maintenance, then don't lift it.
    Itchyfeet likes this.
  6. Nov 30, 2018 at 10:33 AM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    I think it will only cause an issue with affected/changed components.
  7. Nov 30, 2018 at 1:37 PM
    Rjparnow
    Robert
    Taco
    None yet
    It just seems ridiculous that toyota will sell a TRD Pro with a 1" lift, but if you want to convert TRD OR to TRD Pro spec suspension they say it voids warranty or could cause electronic safety issues with sensors. This just doesnt' really make sense to me.
    Does anyone know if the TRD Pro has a diff drop kit installed out the factory?
    Is a diff drop kit needed for a 1" lift? seems like the angle is so minute that it shouldn't really be all that necessary.
    Also, i can only find add a leaf kits for the rear suspension in 1.5". Anyone know where to find a 1" add a leaf kits for the back?
    thanks!
  8. Nov 30, 2018 at 4:30 PM
    JDaw
    JDaw New Member
    2018 Tacoma TRD Off Road
    I checked with my local dealer (Larry H. Miller Spokane) yesterday while waiting for my service. Parts manager said anything under 4" will not void the warranty. Service adviser confirmed. I'm not saying that's the gospel, that's just what I was told.
    MattEcho likes this.
  9. Dec 4, 2018 at 8:24 AM
    Rjparnow
    Robert
    Taco
    None yet
    Does anyone know what the TRDpro uses to lift the rear? is it on 1" blocks or do they come with a TRD pro specific leaf spring which provides the 1" lift?
  10. Dec 8, 2018 at 5:37 PM
    daltondrose
    daltondrose Well-Known Member
    Dalton
    Forest Grove, OR
    2019 Tacoma TRD Pro Voodoo Blue, 2008 FJ MT Sand Storm / White
    • Victory 4x4 front Strike Bumper • Warn Winch Zeon 10 Synthetic • White Knuckle Offroad Rock Rails • Prinsu Full Rack System front and rear • ARB On Board Twin Air Compressor • Nitro 5:29 gears w ARB Air Lockers • 315 70/17 BFG KM3 • 17” Wheels KMC XD with Matching Spare • Decked Storage System • SnugTop Canopy with Windoors • Expedition One Rear Bumper with Dual Swing Outs • Baja Designs Rock Lights • Switch Pros SP 9100 • Victory 4x4 LED Light Bar • Front Baja Designs Driving Lights • Rear Baja Designs Flood Lights • Body Mount Chop (installed by Accessory Outfitters in Aloha, OR) • OME Rear LEAF Springs (soon Deaver Stage III w/ Archive Hammer Hanger) • Ride Rite Airbag System with Daystar airbag free floating cradle • Tailgate panel, Black Mountain Hatch • Tacoma Bed Stiffeners, Chaos Fab • Spindle Gusset, Chaos Fab • ICON 2.5 (58735c FR / 57805P RR) Suspension
    Springs and shocks.
    Also, anybody can refuse warranty work. Nobody can refuse it legally. I have had everything from 12” lifts by Bullet Proof to Revtek spacers on FJ’s, Tundras, and 4Runners... and now Tacoma. I’ve also had aftermarket superchargers... blah blah blah... Not once have I had an issue nor was I ever told it wasn’t under warranty.
    https://consumer.findlaw.com/consum...laws-and-the-magnuson-moss-warranty-act-.html
    I know I am pretty lucky to have some understandable dealers in my area (Portland, OR) Also, most aftermarket (the good ones) will warranty their parts and installation when done by a pro/certified shop. My local Toyota shop does all of their mods and covers everything. I know my buddies all over the US have been super happy with 4WP and their service guarantees. Don’t get caught up in the hype. If Toyota was voiding warranties on their modified trucks over half of the rigs on the road wouldn’t be covered.
    Btw... this is a current brand new 2019 with ProComp 6” lift at the same dealer. I took this today! (For the haters getting ready to call bulls*t)
  11. Dec 8, 2018 at 5:41 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    pop.tremuloides and Sub_Par like this.
  12. Dec 8, 2018 at 5:52 PM
    daltondrose
    Dalton
    Forest Grove, OR
    Here we go...you are correct. That said, a good dealer will always work with you. It’s about sales my friend and return business. Now if someone is an ass and destroys their rig and claims warranty... shame on them. If a part fails because it’s Toyota’s fault then it will be covered. If a person’s neglect or lack of technical and/or professional installation caused the problem, again, shame on them.
    The Magnuson-Moss act wasn’t cited incorrectly, but was a reference for context.
    I speak from experience. I have also left an Easter Egg of Proof in my previous text. I am more than happy to provide references.
    My only point is this: Don’t be afraid to mod your vehicle. Partner with the right dealership, shop, manufacturers, etc. Integrity and partnership are the key to your success.
    If a person so chooses to not modify based on fear... well... that would be a damn shame.
    SEMPER FKN FI
  13. Dec 8, 2018 at 6:01 PM
    Itchyfeet
    It really is up to the dealer to make the call, but don't be surprised when they tell you to get bent.
    Way back in the day a coworker had an Integra GS-R and at 15k had a 2nd gear grind. This was not a granny driver car. The dealer replaced the first transmission under warranty and at 22k the second gear grind was back except this time the dealer told him to get bent no warranty would apply. It was as clear as day the car was being used for motorsports events. If the comp r tires weren't the dead give away the suspension was. I know for a fact he was out beating on that car twice a month at autocross events.
    I can't fault the dealer for saying nope.
  14. Dec 8, 2018 at 6:20 PM
    daltondrose
    Dalton
    Forest Grove, OR
    Agreed! A$$hats need not apply for warranty replacements!
    I can’t stress how far relationships help out in these situations. Get to know your entire eco system. I hand out simple thank you gifts whenever possible. Karma pays in dividends.
  15. Dec 9, 2018 at 5:41 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Was only putting it up there for a reference point for the OP.
  16. Dec 9, 2018 at 5:50 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    My dealer installs lifts, and warranties them. As long as they sell you the parts and do the labor,$$$$$$$. My mechanic installed the lift on my last truck, dealer did not have a problem with it. They know my mechanic, he used to work there.
  17. Dec 9, 2018 at 10:03 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Dealers don’t make the call for warranty work, everything goes through Toyota and they approve or deny claims. Now that said, you can have a dealer who will not mention your mods when asking Toyota to pay for a warranty repair, but don’t be fooled, the dealer never makes these calls unless it’s on their dime.
  18. Dec 9, 2018 at 10:12 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    There is no difference between the leaf springs on your truck and a Pro. The only difference is the shocks. A reasonable dealer will not give you any problems with warranty work if you put on the Pro Fox suspension. Aside from not warranting the specific parts you changed (shocks only) you should be fine.
  19. Dec 9, 2018 at 10:19 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    If the issue isn't suspension related , throw some stock shocks back on before you bring it in and avoid the issue all around .
  20. Jul 17, 2019 at 5:49 PM
    GreyTaco2018
    GreyTaco2018 Member
    2018 TRD Tacoma
    Allpro Sliders
    Dealership selling Icon lifted 2019's. 58k$$$$$$$$$$$$$$
