Will a 2.5" leveling kit make my TRD Sport Taco sit nose up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bocaj77, Apr 10, 2016.
  1. Apr 10, 2016 at 11:27 AM
    Bocaj77
    Bocaj77 [OP] Member
    2006 Silver Tacoma TRD Sport
    I have a 2006 TRD Sport Tacoma and I'm looking at putting a leveling kit on it. I just don't want it to sit nose up. I want to fit 285x70x17 tires on it. I've seen 2.5" spacer leveling kits, but I'm not sure if it will make the truck sit nose up and o don't want it to sit like that. I've also seen 2" leveling kits, but I am not sure if that size tire would fit on it.
  2. Apr 10, 2016 at 11:31 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    yup, it will be nose up.
  3. Apr 10, 2016 at 11:33 AM
    Bocaj77
    Bocaj77 [OP] Member
    Okay. Would I have a lot of rubbing if I put 285x70x17 tires on a 2" leveling kit?
  4. Apr 10, 2016 at 11:34 AM
    Bishop84
    Bishop84 Well-Known Member
    For sure, you have 10+ year old springs in the rear that probably are already sagging a bit if they haven't already broken once.
    It would be smart to replace the entire front strut assembly due to the age of the suspension. Also depending on your location your lower control arm eccentrics are likely seized, which inhibit a front lift from being done properly.
  5. Apr 10, 2016 at 11:38 AM
    Bocaj77
    Bocaj77 [OP] Member
    Would you recommend me putting on all new Bilstein 5100 Monotube Gas Shocks and lifting the front 2.5" and the back .5" to level it out?
  6. Apr 10, 2016 at 11:43 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    5100s and add a leaf
