will a 2 inch lift affect power?
Discussion in '4 Cylinder' started by muleyhunter, Feb 15, 2012.
  1. Feb 15, 2012 at 10:10 PM
    muleyhunter
    muleyhunter [OP] Git-r-Done
    Trevor
    Logan Utah
    07 2.7L 4x4
    Afe Pro dry cold air intake, lce header, dynamax super turbo muffler, scangauge II booming stereo
    Hey guys.I'm thinking of getting a 2 inch lift on my truck but am wondering if doing so on a stock tire size will affect mpg or power? Anyone
  2. Feb 15, 2012 at 10:12 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Lift does not effect gas consumption.
    Larger, heavier tires do.
  3. Feb 15, 2012 at 10:15 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Lift does negatively effect gas consumption. Larger/heavier tires usually has a greater effect on gas consumption then the lift though.
  4. Feb 16, 2012 at 1:45 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Lift will slightly decease highway driving mpg's do to aerodynamics even if you keep stock tires.
  5. Feb 17, 2012 at 11:52 AM
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    Good to know
  6. Feb 19, 2012 at 5:44 PM
    petezny
    petezny Active Member
    Pete
    Long Island
    11 Standard Cab 4cyl 4WD
    Yes I can vouch for that. I keep very detailed fuel logs and I did experience a 1 mpg highway drop just after doing TSB springs two months ago on a standard cab, 4x4, 4cyl. The TSB springs added an inch and a half to two inch lift on the standard cab.
