will a 2012 V6 4.0l fit my 2010 Tacoma V6 HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by *OutlawTRD, Jan 3, 2018.
  1. Jan 3, 2018 at 5:06 PM
    *OutlawTRD
    *OutlawTRD [OP] Well-Known Member
    Jesse
    Socal
    2010 TRD DCSB 4X4
    ^_^
    hello Im about to buy a used engine for my 2010 tacoma 4.0l
    but not sure if a 2012 tacoma 4.0l fit be plug & play???
  2. Jan 3, 2018 at 5:11 PM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    Yes it should fit; however you will be require to re-use some parts off your 2010 engine.
    I think the exhaust manifolds are different due to the air pump design; not sure they came out with that in 2012 or 2013. Everything should plug up; perhaps a few minor changes in sensors but I highly doubt it.
  3. Jan 3, 2018 at 5:24 PM
    *OutlawTRD
    Jesse
    Socal
    2010 TRD DCSB 4X4
    ^_^
    yeah I thought so, Im in the process of buying a 2010 4.0l with 77k on it but then I found this 2012 with 55k not much of a difference for the same price
  4. Jan 3, 2018 at 5:29 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    2012 engines have a lot more emissions systems on them so the ECU and wiring might not be a straight swap
  5. Jan 3, 2018 at 5:32 PM
    *OutlawTRD
    Jesse
    Socal
    2010 TRD DCSB 4X4
    ^_^
    HMM.. OKAY SO FROM 2005-2011 ITS EXACTLY THE SAME PARTS CORRECT??
  6. Jan 3, 2018 at 5:34 PM
    hoarder23
    Shay
    NJ
    Scratches
    I'm not certain, I just know there were several changes from 11 to 12
  7. Jan 3, 2018 at 5:41 PM
    *OutlawTRD
    Jesse
    Socal
    2010 TRD DCSB 4X4
    ^_^
    OKAY THANKS FOR THE HELP:thumbsup:, IM MOST LIKELY GONNA STICK TO A 2010 ENGINE I WANT IT TO BE AN EASY PLUG N PLAY SWAP, CANT WAIT TO HAVE HER RUNNING AGAIN:mudding:
  8. Jan 3, 2018 at 5:51 PM
    Cash13
    Cash13 Well-Known Member
    Northern Colorado
    2014 Tundra
    May I ask why you are doing an engine swap?
  9. Jan 3, 2018 at 6:02 PM
    Pigpen
    Dan
    Northwest Montana
    AND WHY ARE WE YELLING?
  10. Jan 3, 2018 at 6:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    buy the 2012 and you will be able to use everything off the motor sans the exhaust manifolds (hell you could probably use the exhaust manifolds and get block off plates for the air injection ports).
  11. Jan 3, 2018 at 9:32 PM
    *OutlawTRD
    Jesse
    Socal
    2010 TRD DCSB 4X4
    ^_^
    I ran the engine with no oil without noticing it did a lot of internal damage
  12. Jan 4, 2018 at 7:33 AM
    Cash13
    Northern Colorado
    2014 Tundra
    That sucks to hear!
  13. Jan 4, 2018 at 7:53 AM
    Pigpen
    Dan
    Northwest Montana
  14. Jan 4, 2018 at 4:47 PM
    *OutlawTRD
    Jesse
    Socal
    2010 TRD DCSB 4X4
    ^_^
    yup I will never buy a fumoto oil plug again..
    Crosis and PapaBear like this.
  15. Jan 4, 2018 at 4:49 PM
    eon_blue
    Azusa, CA
    Damn, that sucks...I've only heard great things about Fumoto valves. What happened to it?
    scottalot likes this.
  16. Jan 4, 2018 at 4:51 PM
    hoarder23
    Shay
    NJ
    Scratches
    Sounds like someone forgot to close the valve after draining the pan.
    Edit: Rocks is mean
  17. Jan 4, 2018 at 4:53 PM
    *OutlawTRD
    Jesse
    Socal
    2010 TRD DCSB 4X4
    ^_^
    yeah guess it was my bad luck.. I was on a rocky trail and I'm guessing a rock dent my skid plate and destroy my plug :facepalm:
  18. Jan 4, 2018 at 4:55 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Ouch. What? It leaked? Edit: never mind and sorry to hear. SHIT, Man. Shit
  19. Jan 4, 2018 at 5:00 PM
    hoarder23
    Shay
    NJ
    Scratches
    Which version did you have? Nipple or no nipple?
  20. Jan 5, 2018 at 3:09 PM
    *OutlawTRD
    Jesse
    Socal
    2010 TRD DCSB 4X4
    ^_^
    I had the 1 with the nipple
