Will a 245/75R16 fit ok on a 3rd Gen Taco OR OEM wheel?
Discussion in 'Wheels & Tires' started by Hiker46, Sep 27, 2021.
  1. Sep 27, 2021 at 7:02 PM
    Hiker46
    Hiker46 [OP] Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    I'm looking to upgrade to an either C or E rated all-terrain tire and there aren't any in the OEM 265/70R16 size. A bunch of options in 245/75R16 and that size won't change the speedo readings by much. I don't know the wheel width. Would the 245/7516 wheel width of 6.5-8" work?
    Thanks..
  2. Sep 27, 2021 at 7:03 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That’s fine
  3. Sep 27, 2021 at 7:14 PM
    Bishop84
    Bishop84 Well-Known Member
    It will be 100% fine.
    C rated is basically standard load so there's really no reason to chose 245's because of a c rated tire. I'd suggest stock and standard load if thats the only reason.
    I run 245's SL in the winter and 265/75 e rated summer.
  4. Sep 27, 2021 at 7:21 PM
    Hiker46
    Tim
    Colorado
    OVRLND Camper.
    My reason for inquiring about the C or E rating is because I've been running SL rated and have had a couple punctures through the treads. So I figure going up in the rating might help. I drive dirt and rocky Forest Service roads a lot and am planning on doing an Alaska trip next June.
