Will a 285/70R17 fit on an 8.5" wide rim?
Discussion in 'Wheels & Tires' started by ethaniel, Apr 25, 2024.
  1. Apr 25, 2024 at 1:17 PM
    ethaniel
    ethaniel [OP] Active Member
    Ethan
    2023 White Tacoma SR5
    3" Icon Vehicle Dynamics lift
    I found some perfect SCS Ray10 rims that I wanna buy for my truck, but I am planning on getting 285/70R17 tires. I just would like to know if they would fit, because I don't wanna buy everything and then find out it doesn't fit. Rim specs are 17/8.5 -10mm 6x139.7
  2. Apr 25, 2024 at 1:19 PM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Yeah. perfect size...for the wheel.
    As for on the truck... I believe 285s will take some work to fit. Not sure if you are asking about that part.
    gotoman1969 and DavesTaco68 like this.
  3. Apr 25, 2024 at 1:31 PM
    ethaniel
    Ethan
    I've read a lot of websites that said 285s would fit with a 3 inch lift, as long as there's some offset in the rims to push the wheel out a bit. I could be completely wrong, but thats what I've learned from reading websites.... I also plan on getting fender flares in the future and when I do that ill also get some spacers to push the wheels out a bit. I don't think fitting will be a problem, at least i hope. I'll definitely be asking for advice if it is
  4. Apr 25, 2024 at 6:25 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    At some point your suspension will compress unless you stay on pavement all the time. So your truck will be at stock height. You need to fit tires with this in mind.
    Also when you lift 3 inches you’ll have maybe an inch of uptravel left in your shocks, not a great ride.
    https://youtu.be/33VewJFda1Q?si=jTX2y-DvnQTLYV5z
  5. Apr 26, 2024 at 4:20 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    I believe you will need a CMC (cab mount chop) to clear them regardless. Pushing them out with spacers will only make that interference point worse.
    With a 2 or 3" lift should be good after that.
  6. Apr 26, 2024 at 10:53 AM
    ethaniel
    Ethan
    Sorry i didnt specify but I already have a 3" lift
    iwashmycar likes this.
  7. Apr 26, 2024 at 10:54 AM
    ethaniel
    Ethan
    I see, thank you. It is my daily so i definitely spend way more time on pavement than I do off-road
    DavesTaco68[QUOTED] likes this.
  8. Apr 26, 2024 at 9:04 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    It’s not hard to fit 285s, a bit of trimming, do the cab mount chop its cheap to do, and wheel alignment. 285s look awesome in our trucks.
  9. Apr 26, 2024 at 9:08 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    I’d mount the tires then and just trim when you hear rubbing, I drove around on pavement with minimal issues before I did the cmc, good wheel alignment.
  10. Apr 28, 2024 at 6:17 PM
    ethaniel
    Ethan
    I definitely will do
  11. May 2, 2024 at 10:55 AM
    Pista1
    Pista1 Well-Known Member
    Pedro
    Ensenada, Baja, MX
    3rd Gen 18 4x4 TRD Sport
    TRD intake, TRD exhaust, Tuned, 6112's/5160's
    I have 285's with 8.5 width on wheels, no rub, no chop, just good alignment...
    ethaniel[OP] and iwashmycar like this.
