Will a 285 tire fit on the stock spare wheel
Discussion in 'Wheels & Tires' started by EDC_Tacoma, Oct 2, 2021.
  1. Oct 2, 2021 at 7:41 PM
    EDC_Tacoma
    EDC_Tacoma [OP] Active Member
    Can someone please confirm if a 285/70r17 tire will fit on the stock spare wheel?
    The current tire size on the spare wheel right now is P265/65r17.
    I went up to 285 from 265 with new 17 inch Method 305 wheels and I'm planning to get a full size spare to match but I want to avoid having to buy another new wheel along with a tire.
    Stock wheels were the 17inch TRD Sport wheels for the 2nd gen.
  2. Oct 2, 2021 at 7:55 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    285s fit fine on the stock 16" spare on mine. I assume yours is also a 7" wheel so should be fine
    EDC_Tacoma[OP] likes this.
  3. Oct 2, 2021 at 8:28 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    a 285 will fit on your wheel, but the sport wheel does not have enough negative offset, the tire will hit your UCA when you go to put it on when you get a flat.
  4. Oct 2, 2021 at 9:25 PM
    EDC_Tacoma
    Totally forgot about the offset. Thanks for bringing that up. Yea, the sport has a +30 offset and I'm assuming the spare wheels are about the same.
    However, my work around is to only use the spare for my rear tires. If one of my front tires needs replacing then I will move one of my rear tires to the front and use the spare for the rear. It's a lot work but really trying to avoid having to buy another wheel just to have that negative offset.
    I'm assuming that driving with one tire in the rear with a different offset is better than driving it with a smaller tire size.
    skeletron likes this.
  5. Oct 3, 2021 at 11:35 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Just put a skinny on there with the same diameter.
