Will a 2wd axle work for a 4wd?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03gldxcabtrd, Jan 5, 2018.
  1. Jan 5, 2018 at 6:20 PM
    03gldxcabtrd
    03gldxcabtrd [OP] 03 xcab gold 5speed TRD
    Jayme
    Salt Lake city
    03 gold extra cab trd
    6" in dash, 10" kicker powered sub, rhino liner, tko rims, Laffen tires
    I found a good deal on a 2wd axle. I have a 4wd trd. Axles are from the same year. Will it work? As in axle I mean the shaft and not the whole thing.
  2. Jan 6, 2018 at 2:59 AM
    tony2018
    tony2018 Well-Known Member
    I think it depends on whether you have e-locker.
  3. Jan 6, 2018 at 3:12 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    It will so long as it's six lug and has ABS, if it does have ABS but your truck doesn't just cut off the ABS sensor wires and leave the sensors in place to keep the wholes plugged.
    Also be aware that as you have 4wd you need to make sure the gear ratio of the 2wd axel/diff is the same as what you have installed or you will break something first time you use 4wd.
  4. Jan 6, 2018 at 8:51 AM
    03gldxcabtrd
    Jayme
    Salt Lake city
    I was asking about the rear end not the whole axle
  5. Jan 6, 2018 at 8:59 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  6. Jan 6, 2018 at 9:04 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    So you’re asking about a shaft for your rear end?
    tcjacado and Shmellmopwho like this.
  7. Jan 6, 2018 at 9:52 AM
    03gldxcabtrd
    Jayme
    Salt Lake city
    Yes just the rear left shaft. Not the whole assembly.
  8. Jan 6, 2018 at 9:53 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    So is it 5 or 6 lugs? Did you read the links I posted or do you still have further questions?
  9. Jan 6, 2018 at 10:10 AM
    03gldxcabtrd
    Jayme
    Salt Lake city
    I read it, I found one but it's asking if I have 8 or 8.4 and I have no idea what I have under my truck.
  10. Jan 6, 2018 at 10:52 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    8 is the elocker, 8.4 is any other diff in a prerunner / 4wd (read open or non-locking diff). Each of these axles have 6 lugs per wheel. That's the first thing you have to account for. If your truck (which if it's 4wd it's 6 lug) and the replacement axle both have six lugs then you can move on to the next thing to check - ABS vs non-ABS. If the replacement shaft has 5 lugs it won't work.
    Then make sure the replacement axle is from a truck with ABS if your truck has ABS. The ttora link shows that an ABS axle can fit in a non-ABS housing, but a non-ABS axle cannot fit in an ABS housing.
  11. Jan 6, 2018 at 2:32 PM
    03gldxcabtrd
    Jayme
    Salt Lake city
    Any idea what spline comes stock on the 03 tacoma trd? I don't want to order the wrong part.
  12. Jan 6, 2018 at 2:36 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  13. Jan 6, 2018 at 2:40 PM
    03gldxcabtrd
    Jayme
    Salt Lake city
    Any preferred sites you might suggest for the part?
  14. Jan 6, 2018 at 2:44 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    :rofl: I thought it was funny
  15. Jan 6, 2018 at 2:44 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @gunny1005 works for Camelback Toyota. He gives us an additional discount over the usual online dealer price so I wouldn't order one without talking to him on Monday first - it's not like it would ship out until Monday from another site anyway.
    Camelback's website isn't that user friendly for finding part numbers so I usually use partznet.com for finding part numbers.
    If you want a used one you can use car-part.com
    gunny1005 likes this.
  16. Jan 6, 2018 at 2:45 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    me too
    :spy:
