Will a 3 inches lift kit cause a leak of a front differential?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Boyettexan, Oct 13, 2020.
  1. Oct 14, 2020 at 4:42 PM
    SpeySquatch
    2016 TRD OR DCSB
    $1,200 to fix the leak or fix the lift? And yes to the ECGS bushing install. That is a headache to do later
    Skydvrr likes this.
  2. Oct 14, 2020 at 4:47 PM
    eon_blue
    Azusa, CA
    Too much lift...those CV boot fins are crunched up together and will rub apart in no time.
    I haven't heard of a lift causing the axle seals to leak, usually that happens when you remove/reinstall the CV axle and the seal gets damaged, or leaks from age/wear and tear.
    In general though you really should lower that lift down until the CV boot fins are no longer touching each other
    Taco-Obsessed and 71tattooguy like this.
  3. Oct 14, 2020 at 5:33 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Your error was going to the dealer.
  4. Oct 14, 2020 at 5:41 PM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    Diff drop is $30. Just saying
  5. Oct 14, 2020 at 6:05 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Diff drop does almost Zero for 2nd gen and up Tacoma.
    rlx02 likes this.
  6. Oct 14, 2020 at 6:26 PM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    It improves the cv angle. I have it in mine. Works great.
    71tattooguy likes this.
  7. Oct 14, 2020 at 8:37 PM
    SpeySquatch
    2016 TRD OR DCSB
    Completely unnecessary on 3rd gens. I had one and took it out because it was affecting the ride with harmonics because it rotated some of the oil from contacting certain parts. It doesn’t drop the diff, only slightly rotates it.
    They aren’t a good mod for the new trucks.
    Skydvrr and rlx02 like this.
  8. Oct 14, 2020 at 8:37 PM
    SpeySquatch
    2016 TRD OR DCSB
    He’s 100% right and they can do more harm than good.
    rlx02 likes this.
  9. Oct 14, 2020 at 8:46 PM
    eon_blue
    Azusa, CA
    Does almost zero for a first gen too, installed mine a few years back and it didn't change a thing. All they really do is tilt the front of the diff down a tad, they don't drop it all. Not worth the added stress on the diff mount bushings. Best thing is to just keep the lift low enough to where the boots don't rub.
    Texoma[QUOTED] and rlx02 like this.
  10. Oct 14, 2020 at 8:49 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    How did you get those Bilstein 6112s to lift that high? They don’t lift over 2 inches on a 3rd gen. Stiffer springs? Spacers?
    those cv angles no bueno.
  11. Oct 14, 2020 at 9:13 PM
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    While I dont think your lift is causing the leak, those angles are def no good man!
  12. Oct 15, 2020 at 4:01 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Get a digital angle finder and put it on your CV shaft, Zero it. Then remove the diff drop and put the diff back to stock location. Now see just how much of a change it made.
    Taco-Obsessed likes this.
  13. Oct 15, 2020 at 4:55 AM
    Boyettexan
    Boyettexan [OP] Well-Known Member
    Boyette
    77584
    2021 TRD WHITE
    Ironman Nitro Stage 2,Mickey Thompson
    again thank you all for you insight, ill send a message to Duggys Garage today if they can send a representative at the dealer since they offer to show me what has done wrong that causes the leak. ill post back as soon as i get response.
    about the $1,200 its just fixing the leak cause they mention about replacing 2 seals.
  14. Oct 15, 2020 at 6:03 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I'll do it for way cheaper. Save ya close to $1k.
  15. Oct 15, 2020 at 6:58 AM
    #35
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    $1200 to replace a couple of diff deals??? Damn!!! That’s crazy.
  16. Nov 5, 2020 at 2:48 PM
    #36
    Boyettexan
    Boyette
    77584
    2021 TRD WHITE
    to update my issue with my truck ,Oct 15 talked to Devin @duggys garage he kept on insisting that they have nothing to do with the leak so i asked him if he is licensed tech so he can explain it to the Supervisor at the dealership and he said no so he said Dug @duggys will give me a call, talked to Dug @duggys same scenario and but agreed to meet me in the dealership after i told him that its hard for me to explain to the dealership especially i don't know what to say, Dug told me Devin will give me a call as soon as he cleared his schedule, 3 weeks waited to give them enough time consideration of this pandemic,today November 5, not a single phone call, e-mail, messenger just to inform a previous customer that they are still working on their calendar or schedule maybe they dont really honor their word as well as their work? calling them wont be a good thing from me im really upset,mad,being lied to but who knows karma is just around the corner. o_O
  17. Nov 5, 2020 at 2:53 PM
    #37
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Let me know if you'd like my assistance with your diff leak.
