will a 3' lift kit help stop rubbing issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toka670, Jan 6, 2012.
  1. Jan 6, 2012 at 7:12 PM
    toka670
    toka670 [OP] Well-Known Member
    ft bragg
    2010 Rock Warrior
    aftermarket headlights 6000K HID 6000K fog lights smoked LED tail lights
    hello i just wanted to know if i install a 3' lift kit will it stop the rubbing issues? i am running 285/75 R16 on pacer baja champs wheels.
  2. Jan 6, 2012 at 7:13 PM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    You arent running any lift at all right now?
  3. Jan 6, 2012 at 7:14 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    a 3 foot lift would be funny looking.. a 3 inch lift should help a lot with rubbing issues.
  4. Jan 6, 2012 at 7:31 PM
    toka670
    ft bragg
    2010 Rock Warrior
    lol my bad 3 in lift. so it will help?
  5. Jan 6, 2012 at 7:33 PM
    toka670
    ft bragg
    2010 Rock Warrior
    no lift yet.just rubbing bad going to install lift 3 in lift kit next week.
  6. Jan 6, 2012 at 11:26 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    Damn dude that's a big ass tire for no lift I have the same size and am lifted 3" it doesn't rub at all in daily driving but they do rub a little on rare occasions off road, I can't imagine the rub you would get from them with no lift.
  7. Jan 6, 2012 at 11:29 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    It'll probably help a bit in normal driving. You'll need to clearance for those tires though, especially if you intend to drive off road.
  8. Jan 7, 2012 at 12:05 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    Pic please, I want to see that! I'm running 285's also with a 3" lift too..... I still had to cab mount chop, pinch weld and remove fenders for no rub at all
  9. Jan 7, 2012 at 12:43 AM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Pics please. 285's without a lift I have to see this.
  10. Jan 7, 2012 at 8:51 AM
    toka670
    ft bragg
    2010 Rock Warrior
    here it is
  11. Jan 7, 2012 at 11:09 AM
    JasoTaco
    ^ looks good! A lift will help a lot.
  12. Jan 7, 2012 at 11:57 AM
    toka670
    ft bragg
    2010 Rock Warrior
    Will a 3 in spacer lift kit help?
  13. Jan 7, 2012 at 11:57 AM
    T-Rex266
    T-Rex266 T-Rex Moderator
    A 3" will help a lot. I'm running the same size.
  14. Jan 7, 2012 at 1:46 PM
    JasoTaco
    I'm not a huge fan of spacer lifts. A lot of people get spacer lifts but then end up taking them off and buying a better lift. Save your time and money and get a good lift the first time.
    For the money something like this is a much better option.
    http://www.toyteclifts.com/index.ph...tegory_id=113&option=com_virtuemart&Itemid=72
    I have the Toytec Ulitimate lift kit and love it but it does cost a little more. Look around TW you will find all the answers you need :)
  15. Jan 7, 2012 at 5:29 PM
    platinumb
    Patrick
    denver
    X2 on the toytec ultimate I have it and love the ride on and off the road
  16. Jan 7, 2012 at 6:28 PM
    GoDeacsWFU23
    GoDeacsWFU23 Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    you are a prerunner, get a spindle lift
  17. Jan 7, 2012 at 6:30 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    What's the backspacing of the wheels? If its not ideal, you'll still rub even after the lift.
  18. Jan 8, 2012 at 6:32 AM
    toka670
    ft bragg
    2010 Rock Warrior
    i found the offset on the wheels but not the backspacing. offset is -32.00:confused:
  19. Jan 8, 2012 at 6:34 AM
    toka670
    ft bragg
    2010 Rock Warrior
    whats the difference between a spacer lift and a spindle lift? sorry don't know much bout lifts:confused:
  20. Jan 8, 2012 at 7:23 AM
    KPT
    09 Prerunner
    Spacers go inside or on top of the coilover assembly. Spindles connect the uca and the lca on independent suspensions. Lift spindles basically move the wheel hub down lower in the front, providing lift.
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
    Alright well we can use the offset and the rim width to calculate backspacing. What is the width of the rims?
