Will a 33x12.5 on TRD 17" rims fit with no lift?
Discussion in 'Wheels & Tires' started by Rainman443, Aug 30, 2021.
  1. Aug 30, 2021 at 8:21 PM
    Rainman443
    Rainman443 [OP] Well-Known Member
    A Big Island
    2021 TRD OR
    Thinking about pulling the trigger on some 33s, but worried that there could be fitment issues. I don't care much about having to do a CMC or trim up the front fender. More worried about it rubbing the UCA on the TRD rims (7" wide with +4mm offset/3.65" BS) and just plain not being able to fit
    I'm on stock suspension right now, maybe will do a 2" lift in the future but from the videos I've seen, the lift doesn't make a difference in being able to clear a larger tire if you go offroad and compress the suspension anyways.
  2. Sep 9, 2021 at 9:19 AM
    VR812
    VR812 Well-Known Member
    Vincent
    Not sure about 33x12.5, but you can fit a 285/70/17 with the 17" TRD pro wheels. It will clear the UCA, but will need to trim the front fender and possibly CMC.
  3. Sep 10, 2021 at 10:01 PM
    Rainman443
    A Big Island
    2021 TRD OR
    ended up going with 275/70/17 :) rubbed on my mudflap at 1/2 turn in reverse so removed them and all good but then again no offroading yet. Ordered some rokblokz mud flaps and hoping that'll clear the tires
  4. Sep 10, 2021 at 10:13 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Sure they'll fit as long as you don't turn in reverse and make sure your wheels are straight when going over bumps and forget about full lock turns. But yeah they'll fit
    :anonymous::fingerscrossed:
  5. Sep 10, 2021 at 10:16 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Pretty sure a 12.50 is going to be very intimate with the sharp end of the stock upper control arm, regaurdless of how tall the tire is.
    I would definitely get either spacers, which I'm not a fan of, or better offset wheels and upper control arms.
  6. Sep 10, 2021 at 11:04 PM
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    I just put 275/70/17 on sema wheels this week. Fit totally fine at full lock, on incline and in reverse. No rub at all. I'm also on a trd lift
    Any bigger and you will have issues.
