Will a 33x12.5r20 work on 3.5 in lift without rubbing
Discussion in 'Wheels & Tires' started by Baby Blue 07, May 15, 2017.
  1. May 15, 2017 at 12:40 PM
    Baby Blue 07
    Baby Blue 07 [OP] New Member
    drew
    2007 Blue Tacoma TRD
    None yet
    I am going to buy an icon stage 2 3.5 in lift with a 33x12.5r20 tire and a 20x10 maverick wheel. Will I have to trim anything or will they fit fine with no rubbing.
    ChadsPride likes this.
  2. May 15, 2017 at 1:05 PM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
  3. May 15, 2017 at 1:13 PM
    The Taco Bear
    The Taco Bear Well-Known Member
    Franklin, Tennessee
    2018 4Runner TRD Off-Road
    2018 4Runner Off Road TRD SEMA Wheels TRD Skid Plate Prinsu Full Roof Rack RCI Skids Icon 2.5 ext front with resi Icon 2.0 ext rear T13 rear coils Camburg UCA RSG Sliders C4 LoPro 2011 Tacoma TX Pro — Sold Pelfreybilt hybrid bumper Icon 2.5 ext. Non Resi Icon 2.0 Rear with Resi Icon AAL Total Chaos UCAs CaliRaised LED Ditch Lights TRD Exhaust & Intake System TRD Fake Bead Lock Wheels BAMF Sliders Uniden Comm System w/ 4ft fire stick JBL Audio Future Mods: UBolt flip kit with bump stops. Dakars Skids Bed Rack
    This gif is great.
    tacos33, NINK, ChadsPride and 3 others like this.
  4. May 15, 2017 at 1:15 PM
    rpkole
    rpkole Well-Known Member
    Fort Worth, TX
    2014 MGM 4x4 DCSB
    Look at doing Cab mount chop, then BFH to hammer down the pinch weld and you still might rub
    ChadsPride and eccracer104 like this.
  5. May 15, 2017 at 1:15 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    You'll need the -24mm offset / 4.5" BS option to avoid rubbing the spindle/UCA. You will most likely rub the cab mount and the fenders even with your lift.
  6. May 15, 2017 at 1:23 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    2wd or 4wd? if 2wd, you can do a spindle lift and get up above 3". if 4x4, stay at 3'"or less for the sake of your cv axles. or you can drop bracket lift that sucker, and go up to 6"
  7. May 15, 2017 at 4:16 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I had 305/60r18 (32.5x12) tires on a 18x9 0-offset rim. Just barely cleared the UCA. Had to remove the mud flaps and trim the cab mount. This is with a 3" lift.
  8. May 15, 2017 at 7:01 PM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    Shouldn't rub with 20's its a mall crawler so not flexing :D
    Oreo Cat, whiskeytacos and Kyitty like this.
  9. May 15, 2017 at 7:36 PM
    Pigpen
    Dan
    Northwest Montana
    You'll need to cut the cab mount and hammer the pinch weld, as mentioned above. Also as mentioned, don't go over 3" if 4x4. You'll probably still rub a little, as already mentioned.
    Enjoy your mall crawler. If that's who you are, own it with a smile.
  10. May 15, 2017 at 7:38 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    If you are doing 20's why not a 6" DB lift on 35's?
    Yes. You will rub with 12.5" wide tires.
    SamGoingHam likes this.
  11. May 15, 2017 at 7:41 PM
    Pigpen
    Dan
    Northwest Montana
    This
  12. May 15, 2017 at 7:49 PM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    Don't forget to do the stretched tires mod:rofl:
  13. May 15, 2017 at 7:52 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Eeewww.
    To each their own I guess.
  14. May 15, 2017 at 8:18 PM
    Pigpen
    Dan
    Northwest Montana
    Come on. If OP wants 20s, let it be. I wouldn't, but we aren't talking about my truck. 6" lift does look really good with 35s though.
  15. Jun 13, 2017 at 4:30 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    If this was fb I would totally pride heart shocked laughing thumb you up lol
  16. Jun 13, 2017 at 5:07 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
  17. Jun 13, 2017 at 6:59 PM
    Zac of all trades
    Zac
    fwpfab.com
    yeah he knows im stealing his dope gifs! haha.
    at least im pretty sure he made it....
  18. Jun 13, 2017 at 7:00 PM
    T-Rex266
    Elon
    Best. Gif. Ever.
  19. Jun 14, 2017 at 3:49 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    mjp2 likes this.
  20. Jun 14, 2017 at 3:50 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    I even streamed when I was making it.
