Will a camper top from a 2022 Tacoma SWB fit a 2023 SR?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tapel1221, Oct 4, 2024.
  1. Oct 4, 2024 at 3:56 PM
    Tapel1221
    Tapel1221 [OP] New Member
    Therese
    2023 Red Tacoma SR
    I’m looking to buy a used one but I don’t know if it will fit. Both are 5’ beds. Does anybody know?
  2. Oct 4, 2024 at 3:58 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Don’t see why not they are both 3rd gen . Year doesn’t matter as long as it’s made for a 3rd gen and have the same size bed .
    Tapel1221[OP] and Chew like this.
  3. Oct 4, 2024 at 4:00 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    SWB?
    musicisevil likes this.
  4. Oct 4, 2024 at 8:08 PM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    3rd gen campers should fit other third gens as long as it's for the same length bed.
    Edit: I think anyway?
    Tapel1221[OP] likes this.
  5. Oct 4, 2024 at 8:54 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Maybe, maybe not. I don't see a problem with the OP's question. Those should work just fine.
    I may be mistaken but I believe that a 6' Access Cab and a 6' DCLB may not be interchangeable. The beds are the same size, but the shape of the back of the cabs are a little different and you may have some fit issues.
  6. Oct 4, 2024 at 8:54 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Assuming it means short wheel base, as opposed to the long wheel base of the double cabs long beds. Unfortunately not accurate in determining bed lengths since access cabs share the wheel base of a DCSB with the bed length of a DCLB.
    Tocamo[QUOTED] and Tapel1221[OP] like this.
  7. Oct 4, 2024 at 9:11 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Hmm true, you might have issues with some campers if they contour the cab closely.
  8. Oct 5, 2024 at 5:35 AM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    If they are both 4 door short beds then they are the same. I used my camper shell from my 2018 SR on my 2022 SR5.
