Will a full exhaust give me a permanent check engine light?
Discussion in 'Performance and Tuning' started by Tacoma SS, Sep 20, 2015.
  1. Sep 20, 2015 at 12:42 PM
    Tacoma SS
    Tacoma SS [OP] Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    I already have a 3 inch cat back exhaust but I am planning on doing headers and a Y pipe. After doing this I won't have cats anymore, does that mean that I'm permanently going to have a check engine light or is there a way around it?
  2. Sep 20, 2015 at 12:56 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    URD o2 similar will take the cel off but will fail a visual inspection.
    Justus and Torspd like this.
  3. Sep 21, 2015 at 5:16 AM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Dunno where the guy lives. Maybe he should read lotsa posts and see if it matters.
    Really depends where you live OP.
    If they ask for a visual inspection you fail.
    As far as the light, I'm sure it's been covered here.
  4. Sep 21, 2015 at 9:32 AM
    Tacoma SS
    Denver
    Would I be able to do just the Y pipe without getting a check engine light or having to do 02 simulators?
  5. Sep 21, 2015 at 12:51 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Reading some of your other threads about exhaust mods, Sc, headers and etc.
    If you keep the first bank of cats (headers) i dont think you need the O2 sims but if you need it, its a really simple installation (plug'n play) of 10-15 minutes and it's not the more expensive mod.
